Seiko 7009-3040 : bent second hand repair
Hello,
Now going to tackle my second Seiko repair after fixing a displaced 7S26-C rotor/bearing (posted in another thread). I'm still a newbie at all of this, but learning by watching, reading and doing. I'm really enjoying the work, I wonder why I did not learn this art years ago.
I was given a Seiko 7009-3040 automatic for free. I took a look at it and saw that is had a bent second hand. Closer inspection showed the little [ S ] emblem has been disconnected from the face and is rolling around between the dial and the face (show here resting next to the 4 o’clock position. It was actually in the day/date window hiding at first. After a bit of tapping it came out.
I was thinking it might be not too hard to fix?  Separate the  movement from the case of course. Then glue the [ S ] emblem back in place on the dial using a very small amount of super glue. I can see two small holes for mounting. Bend the second hand back to straight.
So the real questions are
  • is super glue OK for this application, I would assume to let the dial stay out of the case for a day or two to protect the rest from 'glue fogging'.
  • looking a the second hand, I'm almost sure it just might break if I try to straiten it?
  • had anyone else seen this happen, the emblem falling off and fouling the hands?
Thank you very much in advance.
Cheers
Yepp . The emblem is best glued from the back. you will get glue on the dial if you glue it from the front . Or the emblem will stick before it's fully in . So put the emblem in the hole and add a small dab of superglue on the tab from the inside.
The second can be straighten if you are careful . Hold it with a tweezer and carefully bend it. Whats is hard is that the paint could crack.
So you have seen this before?
Definitely sounds good to what you suggested, glue from the back. I wonder, is glue what held it in the first place? Looks like this one will be the first that I have to remove and re-install hands. Time for a new too, more learning and practice.
Second hand is painted? I learned something more each day, this being the second watch I have ever worked on.
I'll post some images when I get to the repair. Really appreciate the response.
Cheers
Edited by George19
Cheers
Many times. No idea what kind of glue they use. Think any glue will be fine. As long as it's not a big bloob of glue. Superglue works fine . As long as you let it dry before you put it back. To avoid the "glue fogging"
I didn't look properly. I  thought it looked black. But when i look now i see that it's silver. Then it's no paint on it.
Edited by rogart63
Bend slowly and carefully, inspecting as you go to make sure you are straightening and not putting a correcting bend in if you follow me. And yep, I’ve had loose emblems and hour batons. Always apply glue from back and leave for a couple of days. And post pics of how you get on ;)
Be aware that superglue and some optics don't get on very well. Some types of coated glass, camera lenses for example may be damaged by the cynoacrylate (superglue) fumes.
Try to avoid getting it on acrylic crystals too, although it would probably be possible to polish small spots of superglue from the surface of an acrylic crystal.
Use a pin to transfer the glue in to the spot you want. I tend to use the cheaper stuff, not just 'cos I'm cheap, before someone suggests that, but because it tends to be thin and watery, rather than thick and rubbery. It also tends to have a longer set up time, which is an advantage. Instantly setting things in the wrong position is a nightmare best avoided.
Superglue is soluble in acetone, but then again, so are some dial finishes. :(
Also, avoid cleaning up superglue spillage with cotton wool, or spilling it on your old frayed jeans... the results can be "interesting". I once accidentally superglued a small spot of my denim jeans to my leg, only to watch in amazement as a small whisp of smoke appeared followed by a stabbing pain from the resulting reaction. The reaction makes for some slightly peril laden fun though.
Edited by AndyHull
I understand that. I wonder if I need to remove the hand first or bend it on the pivot as is? Looks not to matter, to re-glue the loose emblem anyway the hands and dial will have to come off. Now I'm off to buy a hand remover and more tools.  This is getting interesting, I love it.
Cheers
The second hand is black. As mentioned, let the glue dry for at least a day as I have experience on other applications.
I have noted that once the glue is dry, there is no issue. The dial will be out of the watch with as mentioned a very small amount applied from the rear of the dial. (thanks for the heads up folks).
Best part, your last paragraph reminds me of one day with *the glue* also when younger. Put my fingertip to the eyelid once, it was not pretty! Your "whisp of smoke..." and all, good story! On drop also landed in the middle of my prescription eye glasses, I now have a center magnifier spot.
Cheers
Cheers
I'm not sure that I would try and do anything with the hand still attached, I'd be too frightened of marking the dial or bending the pinion or something; so I'd agree that as you are taking the hands off anyway best to do it then. And also, yes! It's a great and interesting hobby that just keeps getting more interesting the further down the rabbit hole you go!
First thanks to all that have replied, you make me fell welcome here and that is appreciated.
Well, I've ordered more tools to work on this watch, and others in the future. A hand remover, Rodico, case rest, movement holders, watch press set (for the Timex project), 2ea #3 Dumont tweezers, and a set of real eye loupe's. I can see in the future, oil, oiler's, cleaning machine, better screwdrivers, et all. And down the hole we fall... look forward to it.
Will update once I receive those above and get the time to work on this watch.
Thanks again.
Cheers
  • Similar Content
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
