Hairspring Havoc
Would anyone know how to straighten out the overcoil on this hairspring? It is from a slimline Bulova movement and the mis-shaped overcoil causes the hairspring to sit out of flat so that rubs on the balance wheel. The spring is just slightly out of flat, which would not cause problems on most watches but because of the movements slimness it is a real problem!
I such a case two pairs of tweezers  and a great deal of patience and a steady hand, There is a good U Tube video by Mark on just that.  Before venturing to attempt the job have a look at Marks video then re assess the job based on what you have watched, if you feel confident carry on if not seek further help.all the best in your endeavour,
I find the overcoil very difficult to work on as it is not resting on a flat surface. You need steady hands and make very small adjustments. I recently wrecked a Universal hairspring trying to make a tweek like the one you need. The overcoil somehow got wrapped in the coils. :thumbsd:
Like many I have wrecked several hairsprings.  Often it is just tweezer control.  Working under magnification it is easy to misjudge dimensions, and often I have released the tweezer, with it opening too much only for it to mangle the hairspring. I now have a small elastic band fitted to the shank of the tweezers to limit how much they open when released. The elastic band can be moved up and down the shank to adjust the tweezer gap at the tips.  I have found this helps considerably.  But I still manage to wreck some!!!!!
Two tweezers on a hairspring is always the last resort. Sometimes the only way though. If I was doing this and it was too weird or too little access to do installed with the balance (preferred way), I'd put the spring alone on the cock and try to get it as good as possible then finish with balance in.
mark has some great videos on hairspring manipulation, unfortunately this is one of those things that will be very difficult to explain to someone with words. Best thing to do is watch videos, even videos really dont do much justice. I practice on scrap hairsprings, because one thing is tweezer pressure. Knowing the right amount of pressure is key, too much pressure can cause your hairspring to go in a completely different direction than you initially intended. Me personally I have no patience ( yes i know, why do i repair watches then? well somehow it calms me down kinda like building model airplanes, but the frustration still comes out here and there) so i always just replace the hairspring if its available.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
