Hebdomas Bridge Repair
So I needed to remove a broken screw from the bridge, the one that locks in the Hairspring stud. I first tried drilling it out with small bits from China and this resulted in a peek in the hole. Then I got a great idea and took a bit that broke and filed it down to a wedge,like a screwdriver bit. This got rid in the peek and allowed me to use another bit with cutting oil. And it worked. Used a lathe for this with a collet holding tail stock.
Here are are the pictures.
c696fbb86688ed552e1c763b3643d44b.jpg738c004bb82e7e677e7a3defa33ba7eb.jpgb1f6f6ae9d9e8c2119b29e0f0e924991.jpgccf30104b4a2059943c552a66bacd670.jpgae920cc944472745bd0871f6b715d9af.jpgf67d43c3be69c3414b5d7c65724c405c.jpg2d7f8bcc6bbbe1230876971a1f5a07d4.jpg367fb7cdad468f8ee478d523f1f9b9b4.jpg947c9ca817efce5133dd8ae84ed48fa2.jpg3f16124f633783c753a2edb1f1255ba9.jpgc47c10fc0ab39a1e217e2ea8fc50f8f9.jpgcfa0ac9202d641d0e4715ffc1205005a.jpg
Nice work and good example of how a faceplate can save the day! I do faceplate work all the the time much to the perplexment and eventually enlightenment of apprentices around here.
After all that work, it was still the wrong spring strength. Not sure how to get the right spring for this watch. Should I add weight to the balance?
Sent from my GT-N5110 using Tapatalk
How fast is it running?
Really fast. First, I use e-timer and not sure it can read the frequency, bph. I is only swinging about 90 deg. I really need to figure out the strength of the hairspring I need. Got it working however.
Hi J, Hi Nickelsilver,       JD ,  Have you tried to supply power to the barrel manully, to a normal level ?  Not only tells about MS, it further gives you some idea to judge the escape on.
I suspect the pallets for inadequate or improper impulse supply.
Isn,t the advantage of breguet HS that it lets increase in active length of H not limited by regulator pin? I think you got enough space there to increase the HS  length up to 15 mm, therefore no need to know the exact HS strength.
The hairspring actually stops at the stud, so no way of getting additional hairspring length.
If it came down to replacing with a longer HS. The regulator pin dose not limit the length of breguet HS, as it dose with ordinary HS coil.
Oce sure a new HS is the only option, I would try resonating a plain HS to get the right frequency, leave some extra length on.The overcoil is not as much pain as it is made out to sound. The old HS shows all the right length and bends, it is a model for sculpture. A good parts of the over coil shaping should be done inside the movement, you van see how much to raise and bend to get to impulse pin, end length curve is about the same and is to be done before the raise.
So the watch ifself is our living datasheet. Before getting to this, I must repaeat I agree with Nickelsilver.
On 4/2/2019 at 2:06 PM, nickelsilver said:
You'll want to get the amplitude up before going any further on the timing. With only 90 degrees there must be some serious issues.
Once it came down to replacing the HS. The watch itself is a living datasheet.
No problem to fly a new HS with this BW, inside the watch.
Regards
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
