Hebdomas Bridge Repair
So I needed to remove a broken screw from the bridge, the one that locks in the Hairspring stud. I first tried drilling it out with small bits from China and this resulted in a peek in the hole. Then I got a great idea and took a bit that broke and filed it down to a wedge,like a screwdriver bit. This got rid in the peek and allowed me to use another bit with cutting oil. And it worked. Used a lathe for this with a collet holding tail stock.
Here are are the pictures.
c696fbb86688ed552e1c763b3643d44b.jpg738c004bb82e7e677e7a3defa33ba7eb.jpgb1f6f6ae9d9e8c2119b29e0f0e924991.jpgccf30104b4a2059943c552a66bacd670.jpgae920cc944472745bd0871f6b715d9af.jpgf67d43c3be69c3414b5d7c65724c405c.jpg2d7f8bcc6bbbe1230876971a1f5a07d4.jpg367fb7cdad468f8ee478d523f1f9b9b4.jpg947c9ca817efce5133dd8ae84ed48fa2.jpg3f16124f633783c753a2edb1f1255ba9.jpgc47c10fc0ab39a1e217e2ea8fc50f8f9.jpgcfa0ac9202d641d0e4715ffc1205005a.jpg
Nice work and good example of how a faceplate can save the day! I do faceplate work all the the time much to the perplexment and eventually enlightenment of apprentices around here.
After all that work, it was still the wrong spring strength. Not sure how to get the right spring for this watch. Should I add weight to the balance?
Sent from my GT-N5110 using Tapatalk
How fast is it running?
Really fast. First, I use e-timer and not sure it can read the frequency, bph. I is only swinging about 90 deg. I really need to figure out the strength of the hairspring I need. Got it working however.
Hi J, Hi Nickelsilver,       JD ,  Have you tried to supply power to the barrel manully, to a normal level ?  Not only tells about MS, it further gives you some idea to judge the escape on.
I suspect the pallets for inadequate or improper impulse supply.
Isn,t the advantage of breguet HS that it lets increase in active length of H not limited by regulator pin? I think you got enough space there to increase the HS  length up to 15 mm, therefore no need to know the exact HS strength.
The hairspring actually stops at the stud, so no way of getting additional hairspring length.
If it came down to replacing with a longer HS. The regulator pin dose not limit the length of breguet HS, as it dose with ordinary HS coil.
Oce sure a new HS is the only option, I would try resonating a plain HS to get the right frequency, leave some extra length on.The overcoil is not as much pain as it is made out to sound. The old HS shows all the right length and bends, it is a model for sculpture. A good parts of the over coil shaping should be done inside the movement, you van see how much to raise and bend to get to impulse pin, end length curve is about the same and is to be done before the raise.
So the watch ifself is our living datasheet. Before getting to this, I must repaeat I agree with Nickelsilver.
On 4/2/2019 at 2:06 PM, nickelsilver said:
You'll want to get the amplitude up before going any further on the timing. With only 90 degrees there must be some serious issues.
Once it came down to replacing the HS. The watch itself is a living datasheet.
No problem to fly a new HS with this BW, inside the watch.
Regards
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
