Hebdomas Bridge Repair
So I needed to remove a broken screw from the bridge, the one that locks in the Hairspring stud. I first tried drilling it out with small bits from China and this resulted in a peek in the hole. Then I got a great idea and took a bit that broke and filed it down to a wedge,like a screwdriver bit. This got rid in the peek and allowed me to use another bit with cutting oil. And it worked. Used a lathe for this with a collet holding tail stock.
Here are are the pictures.
c696fbb86688ed552e1c763b3643d44b.jpg738c004bb82e7e677e7a3defa33ba7eb.jpgb1f6f6ae9d9e8c2119b29e0f0e924991.jpgccf30104b4a2059943c552a66bacd670.jpgae920cc944472745bd0871f6b715d9af.jpgf67d43c3be69c3414b5d7c65724c405c.jpg2d7f8bcc6bbbe1230876971a1f5a07d4.jpg367fb7cdad468f8ee478d523f1f9b9b4.jpg947c9ca817efce5133dd8ae84ed48fa2.jpg3f16124f633783c753a2edb1f1255ba9.jpgc47c10fc0ab39a1e217e2ea8fc50f8f9.jpgcfa0ac9202d641d0e4715ffc1205005a.jpg
Nice work and good example of how a faceplate can save the day! I do faceplate work all the the time much to the perplexment and eventually enlightenment of apprentices around here.
After all that work, it was still the wrong spring strength. Not sure how to get the right spring for this watch. Should I add weight to the balance?
Sent from my GT-N5110 using Tapatalk
How fast is it running?
Really fast. First, I use e-timer and not sure it can read the frequency, bph. I is only swinging about 90 deg. I really need to figure out the strength of the hairspring I need. Got it working however.
Hi J, Hi Nickelsilver,       JD ,  Have you tried to supply power to the barrel manully, to a normal level ?  Not only tells about MS, it further gives you some idea to judge the escape on.
I suspect the pallets for inadequate or improper impulse supply.
Isn,t the advantage of breguet HS that it lets increase in active length of H not limited by regulator pin? I think you got enough space there to increase the HS  length up to 15 mm, therefore no need to know the exact HS strength.
The hairspring actually stops at the stud, so no way of getting additional hairspring length.
If it came down to replacing with a longer HS. The regulator pin dose not limit the length of breguet HS, as it dose with ordinary HS coil.
Oce sure a new HS is the only option, I would try resonating a plain HS to get the right frequency, leave some extra length on.The overcoil is not as much pain as it is made out to sound. The old HS shows all the right length and bends, it is a model for sculpture. A good parts of the over coil shaping should be done inside the movement, you van see how much to raise and bend to get to impulse pin, end length curve is about the same and is to be done before the raise.
So the watch ifself is our living datasheet. Before getting to this, I must repaeat I agree with Nickelsilver.
On 4/2/2019 at 2:06 PM, nickelsilver said:
You'll want to get the amplitude up before going any further on the timing. With only 90 degrees there must be some serious issues.
Once it came down to replacing the HS. The watch itself is a living datasheet.
No problem to fly a new HS with this BW, inside the watch.
Regards
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
