Looking for a part! In need of help
Hello.
I am now working on a vintage "trench watch" movement from 1910s that I mentioned before with a question regarding identification of the movement.
(I still haven't got the exact ref. of the movement.)
As I was disassembling the movement, my screwdriver slipped and broke one of the parts that function as a spring for the click.
I tried looking for replacement but I am not sure what I should look for.
Also, one of the jewels on the  wheel bridge is broken so I need a jewel as well.
Could anyone advice me on how to find the correct part for click spring and the jewel for the wheel bridge??
**Could the click spring be put back together??
Thanks. You are always of great help.
First of all we need to id the movement. Could you tell me the size of it and could I have a close up photo of the movement both sides, dial off so I can see the keyless work. Sorry but my eye sight is not so good.
It would be tricky to repair the click, but not impossible.
It wuld need to be silver soldered (Hard soldered) at the break, but done in such a way you don't heat up the whole click as then it would loose its spring.
to be repalce the jewel you would need a jeweling tool.
You need to measure the diameter of the pivot that goes through the broken jewel and the hole the jewel is in.
to measure this you would need to remove the jewel. If the jewel comes out in you part you can just measure the jewel, then you would need to find a Seitz jewel that is the correct size. If you cant find one exactly the same find one with the correct pivot hole and dlightly larger diameter. You would then need to use the jeweling tool  to ream out the hole to the correct size and fit the jewel.
Mark has done a good video on this in the past.
Unless you plan on taking up the hobby serious a jeweling tool will probably be beyond what you want to spend, even a second hand one.
Well that is a good news! May be I should check on Mark's video.
Hope the jeweling tool is not super expensive..haha..
Thank you for your helpful advice!
13 hours ago, rogart63 said:
Ooops . Have a couple of movement with such spring. Not the exact same type but it's AS . Can we measure and maybe i can have one that fits you movement.
Hello. I think the diameter of the movement was around 27mm. I will give you exact measurement when I get home!
One of them is 25 mm . But they both have the same spring. So hope the spring is the same. Have some EB springs to . If the AS is to short one could modify the spring from one of those movements.
Hello! I got the measurements. The size of the movement is 29mm in diameter and the spring is about 14mm in length when measured from one point to another. I want to purchase the part if the size is appropriate.
The one i have is 13,5 so should work. On your watch it looks kind of long. Send me a PM .
Hello! I sent you 10$ as you requested. Have you checked my message??:biggrin:
  • Similar Content
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
