Looking for a part! In need of help
Hello.
I am now working on a vintage "trench watch" movement from 1910s that I mentioned before with a question regarding identification of the movement.
(I still haven't got the exact ref. of the movement.)
As I was disassembling the movement, my screwdriver slipped and broke one of the parts that function as a spring for the click.
I tried looking for replacement but I am not sure what I should look for.
Also, one of the jewels on the  wheel bridge is broken so I need a jewel as well.
Could anyone advice me on how to find the correct part for click spring and the jewel for the wheel bridge??
**Could the click spring be put back together??
Thanks. You are always of great help.
First of all we need to id the movement. Could you tell me the size of it and could I have a close up photo of the movement both sides, dial off so I can see the keyless work. Sorry but my eye sight is not so good.
It would be tricky to repair the click, but not impossible.
It wuld need to be silver soldered (Hard soldered) at the break, but done in such a way you don't heat up the whole click as then it would loose its spring.
to be repalce the jewel you would need a jeweling tool.
You need to measure the diameter of the pivot that goes through the broken jewel and the hole the jewel is in.
to measure this you would need to remove the jewel. If the jewel comes out in you part you can just measure the jewel, then you would need to find a Seitz jewel that is the correct size. If you cant find one exactly the same find one with the correct pivot hole and dlightly larger diameter. You would then need to use the jeweling tool  to ream out the hole to the correct size and fit the jewel.
Mark has done a good video on this in the past.
Unless you plan on taking up the hobby serious a jeweling tool will probably be beyond what you want to spend, even a second hand one.
Well that is a good news! May be I should check on Mark's video.
Hope the jeweling tool is not super expensive..haha..
Thank you for your helpful advice!
13 hours ago, rogart63 said:
Ooops . Have a couple of movement with such spring. Not the exact same type but it's AS . Can we measure and maybe i can have one that fits you movement.
Hello. I think the diameter of the movement was around 27mm. I will give you exact measurement when I get home!
One of them is 25 mm . But they both have the same spring. So hope the spring is the same. Have some EB springs to . If the AS is to short one could modify the spring from one of those movements.
Hello! I got the measurements. The size of the movement is 29mm in diameter and the spring is about 14mm in length when measured from one point to another. I want to purchase the part if the size is appropriate.
The one i have is 13,5 so should work. On your watch it looks kind of long. Send me a PM .
Hello! I sent you 10$ as you requested. Have you checked my message??:biggrin:
  • Similar Content
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
