Seiko 6119 runs slow after service.
Baird
Hey all.
So I recently picked up a 6119 Seiko with a case in great shape, but the movement wasn't great.  It barely ran and wouldn't wind correctly.   So I took it apart to find that someone else had been in it.  The mainspring barrel wasn't even closed correctly and there was oil all over the place.   After a thorough cleaning and re-oiling, the watch runs and winds correctly, but the timegrapher is all over the place, almost as though the mainspring installed is way too strong.  Also, it runs about 20-40 minutes slow a day even when adjusted all the way to the +.
Could it be that it has the incorrect mainspring?  Is that plausible?  I took it apart and redid it twice thinking maybe I missed something on the initial service, but the result was the same.  Also, I can't seem to find a factory mainspring for this movement.  I'm a novice hobbyist at all of this, so I am unsure of how to calculate or find specs that I would need for a generic mainspring.  It may not be that, but I just can't find anything else wrong with it.
Any help would be appreciated.
Thanks!
Yes, This mainspring can be the wrong one.
Genuine seiko MS are said to have gone extinct, though you can find ones for sale on ebay advet  as NOS gen. Dosn,t say genuine just gen, which could very well stand for generic.
Your watch should run fast  if  it,s  mainspring  is strong.
How do you know it winds well or full. The fault can be insufficient power.
How long dose it run, on what you presume to be full wind?
Spindle may slip inside the barrel and discharge power or auto winder may fail to wind  beyound some point.
I normally suggest giving it a good wind, manually through the ratchet wheel and note how long it runs and listen close for the sound of possible power discharge as you wind. We then have more data and can decide to right course.
Regards
Regards
I did wind it with the ratchet wheel at first. I didn’t note how long it ran but I definitely know it was running at least 24 hrs later.
Hi  Tech sheet PDF enclosed 401-615 mainspring is now obsolete (cousinsuk).  Nucejoe is on the mark check that the spring is not slipping and loosing power, remove balance and fork apply a bit of power, do the train wheels spin and backrun at the end, sounds like a power problem.
3106_Seiko 6119A.pdf
I don’t recall them doing that but I will do so and check. Thanks.
A lot of the Seikos don't backrun- I think the 6119 is one of them IIRC.
I use the GR25341x mainspring (Cousins have them) in the 6119, 6139 etc.
Also, I read somewhere that the rate of the watch is often inversely correlated with the amplitude- i.e. low amplitude= faster rate and vice versa. An over-powered mainspring would cause I higher amplitude (I think?), hence a slower rate. Would be good to hear others' thoughts on this...
Interesting. I had a chance to sit down with it today and I didn’t see any backrun. Also, it looks like the balance is barely swinging which normally would make me think it’s going to run out of control fast. But sure enough, it’s running slow still. Could it be a hairspring issue? I made sure to demagnetize just to be sure, and the balance swings freely. I can’t see anything wrong with it.
Cousins is listing the GR2534x as a substitute - 1.05x.115x420x10.5. More expensive (£16.50) than they're selling the GR25341x suggested above (£7.95). They appear to have the same dimensions.
OK what jumps out at me here is two things: someone else was in the watch, and barrel cover was barely on
so maybe the last person put the wrong size mainspring in the watch which is why the lid opened. if the mainspring is too wide then it will be rubbing up against the barrel lid which will cause a huge loss in power. you dont need an OEM spring you can find an aftermarket if you dont know size and type you can get a mainspring gauge and look at the chart on ofrei for end style.
Is seiko 6119 movement the one with metal hole instead of stones jewels, on gear train bridge?
That thing not only dose backrun it wnot even forth ran, I got one, ended up installing a bridge out of 6139 that comes with stone jewels, run real good now.
Sorry.
This one has jewels.
I think I’m going to try the mainspring route next and see what happens.
Good idea, proper MS and barrel greasing. Enhancement. !!
So I bought the mainspring from cousins. Still slow. I swear I think I’m missing something. An obstruction or something worn.
Thanks for the advice though everyone.
did you grease the barrel? did you regulate the watch?
if you did properly then there can be a piece of dirt or debris hiding somewhere slowing everything down
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
