  • 0
Baird
Seiko 6119 runs slow after service.
Question
Hey all.
So I recently picked up a 6119 Seiko with a case in great shape, but the movement wasn't great.  It barely ran and wouldn't wind correctly.   So I took it apart to find that someone else had been in it.  The mainspring barrel wasn't even closed correctly and there was oil all over the place.   After a thorough cleaning and re-oiling, the watch runs and winds correctly, but the timegrapher is all over the place, almost as though the mainspring installed is way too strong.  Also, it runs about 20-40 minutes slow a day even when adjusted all the way to the +.
Could it be that it has the incorrect mainspring?  Is that plausible?  I took it apart and redid it twice thinking maybe I missed something on the initial service, but the result was the same.  Also, I can't seem to find a factory mainspring for this movement.  I'm a novice hobbyist at all of this, so I am unsure of how to calculate or find specs that I would need for a generic mainspring.  It may not be that, but I just can't find anything else wrong with it.
Any help would be appreciated.
Thanks!
Share this post
Link to post
14 answers to this question
  • 0
Yes, This mainspring can be the wrong one.
Genuine seiko MS are said to have gone extinct, though you can find ones for sale on ebay advet  as NOS gen. Dosn,t say genuine just gen, which could very well stand for generic.
Your watch should run fast  if  it,s  mainspring  is strong.
How do you know it winds well or full. The fault can be insufficient power.
How long dose it run, on what you presume to be full wind?
Spindle may slip inside the barrel and discharge power or auto winder may fail to wind  beyound some point.
I normally suggest giving it a good wind, manually through the ratchet wheel and note how long it runs and listen close for the sound of possible power discharge as you wind. We then have more data and can decide to right course.
Regards
Share this post
Link to post
  • 0
Regards
I did wind it with the ratchet wheel at first. I didn’t note how long it ran but I definitely know it was running at least 24 hrs later.
Share this post
Link to post
  • 0
Hi  Tech sheet PDF enclosed 401-615 mainspring is now obsolete (cousinsuk).  Nucejoe is on the mark check that the spring is not slipping and loosing power, remove balance and fork apply a bit of power, do the train wheels spin and backrun at the end, sounds like a power problem.
3106_Seiko 6119A.pdf
I don’t recall them doing that but I will do so and check. Thanks.
Share this post
Link to post
  • 0
A lot of the Seikos don't backrun- I think the 6119 is one of them IIRC.
I use the GR25341x mainspring (Cousins have them) in the 6119, 6139 etc.
Also, I read somewhere that the rate of the watch is often inversely correlated with the amplitude- i.e. low amplitude= faster rate and vice versa. An over-powered mainspring would cause I higher amplitude (I think?), hence a slower rate. Would be good to hear others' thoughts on this...
Share this post
Link to post
  • 0
Interesting. I had a chance to sit down with it today and I didn’t see any backrun. Also, it looks like the balance is barely swinging which normally would make me think it’s going to run out of control fast. But sure enough, it’s running slow still. Could it be a hairspring issue? I made sure to demagnetize just to be sure, and the balance swings freely. I can’t see anything wrong with it.
Share this post
Link to post
  • 0
Cousins is listing the GR2534x as a substitute - 1.05x.115x420x10.5. More expensive (£16.50) than they're selling the GR25341x suggested above (£7.95). They appear to have the same dimensions.
Share this post
Link to post
  • 0
OK what jumps out at me here is two things: someone else was in the watch, and barrel cover was barely on
so maybe the last person put the wrong size mainspring in the watch which is why the lid opened. if the mainspring is too wide then it will be rubbing up against the barrel lid which will cause a huge loss in power. you dont need an OEM spring you can find an aftermarket if you dont know size and type you can get a mainspring gauge and look at the chart on ofrei for end style.
Share this post
Link to post
  • 0
Is seiko 6119 movement the one with metal hole instead of stones jewels, on gear train bridge?
That thing not only dose backrun it wnot even forth ran, I got one, ended up installing a bridge out of 6139 that comes with stone jewels, run real good now.
Share this post
Link to post
  • 0
Sorry.
Share this post
Link to post
  • 0
This one has jewels.
I think I’m going to try the mainspring route next and see what happens.
Share this post
Link to post
  • 0
Good idea, proper MS and barrel greasing. Enhancement. !!
Share this post
Link to post
  • 0
So I bought the mainspring from cousins. Still slow. I swear I think I’m missing something. An obstruction or something worn.
Thanks for the advice though everyone.
Share this post
Link to post
  • 0
did you grease the barrel? did you regulate the watch?
if you did properly then there can be a piece of dirt or debris hiding somewhere slowing everything down
Share this post
Link to post
Answer this question...
Loading...
    • I have a lot of confidence in @Mark so that video section answers all my questions! Lube the automatic mainspring with Moebius 8200 and apply braking grease to the barrel wall. The 8200 will protect the spring and make it just slippery enough to help winding it into a mainspring winder without breaking. Obviously, the very thin layer of 8200 will not defeat the effect of the braking grease, or that is at least my interpretation of the video passage. Nevertheless, I agree with many that the best path is to replace the mainspring if one is available when servicing.
    • Just curious; did you get a chance to look at the date wheel issue again? If so, I do hope you were successful in finding the source of the problem and can share it with us!? The calendar works of the 2472 is the most sophisticated I've come across so far with its instant date change where the date wheel doesn't move one bit until it flips over in a blink. So fascinating I recorded a video of it here.
    • a new mainspring is always needed when doing a service/overhaul. new alloy mainsprings come with a dry lube so you may think they are not lubed but they are, . if you reusing a mainspring which i do not recommend then you have to clean off the old oil first if there is any and then use a piece of watch paper coated with oil then put it between tweezers and run the spring through it. I cant recommend an oil because i have never reused a spring but i can say it wont be 8200 since it is a natural oil and can spread and contaminate your barrel and movement. there really is NO reason to oil a mainspring except for maybe rust protection when dealing with very old NOS blue steel springs, or if the manufacturer specifies. I personally never oil automatic springs since most automatics i work on are modern and use white alloy springs, which again already come pre lubed. Some springs have a teflon coating which looks blue that will have to be removed prior to install to prevent emulsion from forming. Has anyone tested the power reserve in auto with dry spring vs one that has a lubed spring? Do that then decide for yourself
    • Update, here Mark joined the lubing camp.
    • I'm not sure how the OP thinks he can do this, but if with the stone in the fork, assuming it would be even possible, then the stone will become too short and not have the right lock and draw. Faulty stones should be replaced.
