Space Age Timex?
I have yellow and orange versions of this watch I picked up from a charity shop they are from a range of watches called "Fun Timer" from the late 60's early 1970's they are one piece plastic cases, not bad to say they where 15 years ahead of Swatch.
Do they have a standard (and thus repairable) mechanism. If so they are 1,000 years ahead of Swatch. :D
yes they are from the fun timer series and here is the service bulletin on how to remove the stem.
strange that I have never had one.  I'm guessing 1970's but I don't see them in any of the catalogs I have.
The 70's was a fantastic era in shape, styling and use of color for the watch industry.
Edited by JerseyMo
add
  • 1 year later...
  • 2 years later...
I just won one of these on auction. It appears in a supplement to the 1973 catalog https://heritage1854.com/1973catalog-reference
I'm glad I stumbled on your post of the stem removal before chewing up the case to figure it out.
    • This set lever seems to working ok unhardened Nickelsilver, might it deform if i leave it that way ?
    • I found this from a while back CS100 seems fine, but at around 500 Vickers it's not quite as hard as "blue" steel, but still harder than annealed. I'd try to find annealed (the post above has a U.K. supplier of small quantities).
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.  Thanks, Nev. Amplitude v. weak - balance wheel turns over arc of only ~20deg. Don't know how to calculate movement rate or safely vibrate balance spring! Meantime I have reduced the 'dishing' & clock no longer runs for more than a few minutes except face down which supports my theory that it was 'dished' as a hack to avoid doing a proper repair.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
