Space Age Timex?
I have yellow and orange versions of this watch I picked up from a charity shop they are from a range of watches called "Fun Timer" from the late 60's early 1970's they are one piece plastic cases, not bad to say they where 15 years ahead of Swatch.
Do they have a standard (and thus repairable) mechanism. If so they are 1,000 years ahead of Swatch. :D
yes they are from the fun timer series and here is the service bulletin on how to remove the stem.
strange that I have never had one.  I'm guessing 1970's but I don't see them in any of the catalogs I have.
The 70's was a fantastic era in shape, styling and use of color for the watch industry.
Edited by JerseyMo
add
  • 1 year later...
  • 2 years later...
I just won one of these on auction. It appears in a supplement to the 1973 catalog https://heritage1854.com/1973catalog-reference
I'm glad I stumbled on your post of the stem removal before chewing up the case to figure it out.
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
