Watch running fast
Hi,
I am new to this forum, and a beginner in watchmakig as a hobby. Recently i bought a timing machine to check the accuracy of an old Pronto watch (CAL. 2750). I tested the watch, it was running around 45 seconds fast and the beat etter was high. I then tried to adjust the beat error on the watch by adjusting the stund on the balance.
Tested the watch again, and it was running crazy fast, around 900 sec+ a day. I have tried to demagnetize the watch, and it is now running at different rates between +240 to + 450. The balance spring looks fine in my eyes, no touching parts. Can anyone hjelp me find the fault?
Hmmm... tricky. Did you take a picture before you adjusted it?
I suspect the hs is now catching on the slot in the rate adjuster, or the  hs has been deformed slightly and coils are touching, or the hs is now dirty for some reason. Also check the balance pivots are still intact.
I agree with Andy, HS issue.
Faulty HS end length, or the slit catches/ carries the HS.
Move the adjust arm all the way towards the stud, that is max HS length activation. Readings on timegrapher should not vary then.
if it is running fast and has a beat error then the watch will need be adjusted not regulated. regulating (moving regulator stud to fast or slow) will not correct beat error. beat error occurs when the balance wheel will rotate lets say 360 degrees in one direction, then 270 degrees in the opposite direction. Normal osculation should be about 270 degrees in both directions.
1. Observe the HS and BW under a strong eye loop. Is the the BW moving in fast short strokes (usual cause is magnetism), or is it moving wildly fast in long strokes. best way to see this is if you have a smart phone with slow motion feature record the BW then watch it in slow motion and you can get an idea of the degree in rotation and get an idea which direction is off. also under magnification watch the HS coils expand and contract, are any of the coils sticking, is the HS riding up or not laying completely flat.
2. Demagnetize the movement and balance assembly separately. remove pallet and cock and reinstall balance asbly. make sure the roller jewel rests in the middle of of the banking pins. if it does not then there is your "beat error" problem. you will have to adjust the HS collet on the BW untill that roller jewel is dead center in the banking pins. there is a way to do this with spring attached but that requires experience so HS will have to come off. remove the stud from the cock and observe how the HS sits on the BW, make sure there are no warped or sticking coils. if all is good then make your adjustment and reattach stud. time the watch again and see if there is any issues.
3. If there are still timing issues then a full service is in order. pivots will need to be checked for deformities and/or wear. picot jewels will need to be stripped and cleaned of old oil and debris, etc. End/side shakes of the BW should also checked before service begins.
A TIMING issue is a sure sign that a SERVICE is in order, so I will recommend a full service either way for this watch regardless of what the fault is. But I always like to do some fault finding first (things mention above) then proceed with the service, you will also be doing other quality control inspections during the duration of the service. i.e checking pivots, pivot jewels, mainspring, pinions and teeth, end/ side shakes of train, etc.
demagnetize the the movement and
Edited by saswatch88
  • Thanks 2
HS end length is correctly shaped if collet stays right on top of the jewel hole, as you move the adjust arm through entire HS end length. If badly shaped you vary the conditions on HS as you move adjust arm.that is;  at one adjust position you may advance the impulse jewel while at anthor postion of adjust you retard. In other words you would be introducing error to the impulse jewel position while trying to adjust.
Not to mention other problems, improper HS shape brings.
That I think is what andy refers to, he is thinking. drastic difference reading could easily be due to the HS shape altering at dif adjust position, all due to bad  shape of HS end length or unsmoothness there.
I have a question to ask of andy,  How do interpret the change in slope of the gragh?
Thanks in advance.
The HS coils may be sticking intermittently, this typically results in a wavering graph. There may be some issue with the power train, dirt or damage, which can also show a wavering result, or the oscillator may be so far out of beat, that it has some secondary component to its oscillation. If you check Mark's videos, they may help.
Hi, sorry, no picture before i adjusted it. The hs looks good, will try to clean it and see if it helps.
Thanks for all the replies! Have tried to demag the movement (hairspring and movement separately). The hs looks good, can´t see it touch anything. This movement has not been cleand by me, so will try to do a full service and see what happens. Think i have to adjust the watch in beat as well, so will do a full service, adjust and cross my fingers. Thanks to all of you!
update the forum on your progress
1- Dispower the barrel at the click.
2- move adjust arm through the entire end length of the HS, ( from max retard,  to max advance) if that causes the BW move at all, the end length is wrongly shaped, In which case you are varying the impulse jewel beat as you move the adjust arm.
The impulse jewel should stay in beat as you move adjust arm.
On ‎3‎/‎30‎/‎2019 at 12:58 AM, clockboy said:
Have you fitted a new mainspring. The hairspring looks good it is just running way to fast.
    if the balance is not magnetized,  put the regulator  in middle position and bend the hair spring till it is in beat.  there are books that show you how to do this.  vin
I finally had some time to work with my watch today. Tried Nucejoe’s tip quoted above, but the BW did not move. As some of you suggested, i decided to clean the  balance only, before starting a full service. After some time in OneDip and drying, i started reassembling the balance and adjusting the watch in the timegrapher.
The watch beat is now looking good! The time is also a lot better now, haha. My only concern is the amplitude, it’s really low.
you have friction somewhere, most likely due to dirt and/or dry pivots/mainspring. this watch needs a full service. new mainspring, cleaning and proper oiling. the watch is still slightly out of beat a little more work and it will be good to go
  • Thanks 2
I add power to the barrel manually. Just push to turn the barrel in direction it supplies power, If the amplitude flies, power supply is to be checked and MS tested.
If the amplitude remains the same or BW locks up ..etc, the issue is with the escapement.
Also check if end stones push on pivots.
23 hours ago, AndyHull said:
Assuming the watch is fully wound, I would suspect the low amplitude may be associated with a weak or dirty mainspring, or dirt somewhere in the power train.
Yes, it was fully wound.
Thanks, will do a full service when i have time to sit down with this project!
Wow, nice tip! Will definitly check this out, before starting a service.
This forum is great, thanks to all of you! I’m learning a lot.
Needless to say, the slight amout of power to add is what we feel the power source fails to supply. Strongly pushed the escape will lock.
I agree with saswatch on both counts, friction and slightly out of beat.
yea good idea nuce! force power through the mainspring. best way to do this i would think is fully wind it then push on the ratchet wheel with pegwood and hold it, dont let it seat back into the click. see if amp goes up and then see if it drops when you let it go and ratchet sits back into the click.
I
I like your approach for being more suitable especially when the movement is assembled mounted on move- holder and to the TG.    Regards
A little update:
Stripped down the movement, cleaned the pivotholes with pegwood and ran the parts in the ultrasonic cleaner.
I then lubricated the old mainspring and put it back together. Assembled the wheels and bridge and oiled the pivots. That’s all for now, and i think the wheels are spinning good. Will keep you updated.
On the last picture, movement before cleaning to the left, cleaned to the right.
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
