Dial will fit 2824 AND 8515?
So I'm working my way through my first project watch.  I'm sourcing parts on eBay and trying to assemble my first wristwatch.
I started with a case, hands, bracelet, and a Miyota 8515 movement.  I found a dial that I just FELL IN LOVE WITH:
The eBay description said the dial would fit BOTH and ETA 2824 and a Miyota 8515.  OK, whatever.  They can't put it on the internet if it isn't true.  So I ordered it.
When it arrives, I tried to mount the dial on the Miyota 8515 and it absolutely would not fit.   The dial feet wouldn't match up.
Well, I guess I'm a slow learner.  I ordered a Chinese ETA 2824 clone and new hands.  When they arrived, big surprise, it wouldn't mount.  Again, the dial feet:
I'm thinking it's only suppose to have TWO dial feet, and maybe I'm suppose to trim off one pair for the 2824 and the other pair for the 8515.  Does that make any sense?
Any feedback would be appreciated.
phy
What sort of references are you looking for? I'm guessing there were no instructions with the dial. However if you identify the dial fixing screws on the movement you want to use it should be easy to work out which feet to remove.
So I checked a few tech drawings, looked over my ETA 2824 clone movement, and decided what feet I needed to keep and what feet I needed to remove.  I plugged in my Dremel and cut off a foot.  Checked again, and it was one of the ones I needed to keep.
sigh....
Well, I cut off the two that DID need to get cut off, then ordered some dial dots.
I fit the dial on the movement and fit the hands.  Then I wound the movement and let it run.  The hands jammed.  A little "adjusting" and the hands ran OK.  Then I put the dial & movement in the case.  It wiggles.  I need a movement ring, which I have no idea how to source.  Or fit, so that the movement gets held firmly in place but the rotor still turns.
Someone PLEASE remind me why I decided to build my own watch and not just buy an Invicta off of the Home Shopping Channel?
One other thing I learned - Adjustable movement holders SUCK.  I'm ordering an aluminum 2428/2436 movement holder off of eBay today.
By the time I'm done building this watch with its cheap Chinese movement, after buying & re-buying parts, and buying tools, oh God the money I've spent on tools, and am still spending, and all the time I've spent, I could have bought a Grand Seiko.
If you know anyone with a 3D printer, you can get them to print you a custom movement holder or dial ring, or even a crystal spacer.
You *might* also get away with re-purposing a movement holder from a quartz watch.
A couple of the "Indian Special" that I picked up recently used cut down quartz movement rings.
Not a particularly elegant solution perhaps, but maybe it would do a turn till you get something a little more suitable.
Edited by AndyHull
Speaking of watches and 3D printers...
I know a company in Boston, only a few miles down the road from me, that buys old American pocket watch movements.
There were several major companies in the States around 1900 that were cranking out pocket watches in numbers like a million a month.  One of these, Waltham, was about halfway between me and Boston, but there was also Hamilton, Eglin, and Illinois Watch Company.  Some of the Rail Road Grade movements were the equivalent of COSC certified chronometers.  During the Great Depression of the 1930s most of these that had silver or gold cases had the cases sold for scrap.  The naked movements were left in sock drawers across the country for decades.
Now antique stores all across America all have dozens of vintage pocket watches in them, along with a few dozen naked vintage movements, and some of these at one time Rail Road grade, plus BUCKETS of random vintage pocket watch parts.
This Boston company is buying up these vintage movements and refurbishing them.  They are bring the Rail Road grade movements back to near COSC chronometer timekeeping.  And because it's a pocket watch movement they have ~60 hours of reserve from a full wind.
Then they have banks of 3D printers that can "print" in metal.  They print wristwatch cases out of brass, bronze, tin, aluminum, and steel.  Some of them are really beautiful.
And they sell these refurbished wrist pocket watches for modern Swiss watch prices.
I got the replacement dial I ordered.  I trimmed the correct dial feet this time, applied the dial to the movement and then the hands.
I wound the movement and I'm going to let it run for 24 hours to make sure the hands don't jam.  If it's running smoothly tomorrow night then I will case it up.
Wish me luck.
Can I jump in on this thread with a related question? in addition to aliEpx sellers selling dials that fix eta and miyota there are also cases listed as fitting ETA2824 and Miyota 82 series but those movements have different stem heights (1.8MM v 2.5mm).
How does that work ?
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
    • Haha. You're just in a wicked mood today John 😅
