Small staking set (no frame)
I just bought this little set at a mart and am wondering exactly what I have and whether the necessary parts are there to use it. It's obviously a small swiss staking set (Star brand), for watchmaking I presume.
There's a large round flat stump on the right, screwed into a hole in the box, for hammering on I suppose.
There is no frame, just a die plate that fits into a round "holder" as you can see from the photos below. Under the die plate are holes around the outside that fit into the knob in the round holder center recess to secure the die in place. The other hole in the round holder center recess allows the 4mm stakes to fit through. The larger round hole in the center recess is possibly just to fit onto the placement rod at the center of the box, to prevent the assembly from moving around too much when stored inside?
There is a long piece on the left that is meant to be secured in a vice, which has a flat surface on one end, and a taper with hole in the center at the other end. The stakes are 4mm in diameter and don't fit into the hole in the tapered end.
Is there something missing and if not, how is this staking set meant to be used (as opposed to a more usual staking set with a frame, which I have).  I suppose for small staking jobs that could be done on a bench and would not need the perfect perpendicularity that a frame provides for the stake hitting the work?
I also attach a catalog listing of a similar tool from the 1920's, in France.
Thank you, in advance, for your insights and expertise.
Super interesting!! I hadn’t seen any staking tool without a shaft to guide the stakes. There has to be a away set things up. I wonder if these sets are more accessories to a basic set rather than the whole tool by itself.
I’m interested to learn more about this! Let’s see what the gurus have to say [emoji1303]
Hi rstl99   Yes it looks all there apart from a few gaps these are ok for general work, for balance work etc you need the  proper up right staking tool with rotating table and punches.  If you google watchmakers stanikng set or do the  same on ebay you will see what I mean therer are many makes K&D Star and many more.
Hi everyone and thanks for your feedback and suggestions.
I do own a full sized K&D Inverto staking set with all the necessary stakes and stumps.
But I had not seen a pared-down little staking set like the one I just bought.  Indeed, it has similarities to the one for clockwork showed above, but mine is quite small and dainty, and suited for watchwork (stakes are 4mm diameter, and some have very tiny holes in the centre).
A few months before, I had bought from the same seller a small set of stakes that I now realize were an accessory to this recent staking set I acquired.  In combining and organizing the stakes I made up a pretty complete set, and filled out the box containing the die plate and two flat anvils.
I'm thinking that perhaps there was a time when all staking sets were like this, before the companies invented the frame holder which aligns the stake to the die plate.  And that some watchmakers liked to use the frame-less set for some tasks, so companies kept making them (until the 1920's anyway, based on that catalog entry).  And that for some tasks, the simpler die plate and stakes are all that is needed.
Anyway, I'll use it for odd little jobs (maybe repairing fusee chains) and eventually will discover tasks it's well suited for.  I haven't yet seen such a set described in any watchmaker book that I own, as the staking sets described are always the ones with the frame.
Cheers.
For anyone still looking at this thread, my little research has only yielded that such a set was called a "set of punches".  It seems to pre-date the "staking set" that we are all much more familiar with in watchmaking parlance.  Although similar but larger "punch sets" are still made and sold, for use in clock repair (as one of the photos above attests).  For watches, the staking set reigns supreme.  However there are no doubt some situations where a "set of punches" like the one pictured above will prove useful.
  • 3 years later...
I had this type and many more like it, the center piece/block is used in the same way as if it had a stand. Hardly ever used it for watch work, as I had two sets complete with the stands. Centering was a bugger.
Edited by oldhippy
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
