Help identifying vintage Movement
H8CAK
You will see from s movement I worked on a few weeks ago that it has the same shield logo with a T in it. This movement was Dimier Frères and was very similar to an AS 676. I’m not sure if this will help you but my watch was from the same era (1920s).
It's an AS movement. TR is Ebauches Trust the forerunner of Ebauches SA, ETA, and in simplified terms was an umbrella organisation for most Ebauches makers in the old days. AS was a founder member. There's loads about Ebauches SA if you google it, all gets a bit complicated.
complicated like the movements when it comes to sourcing parts
It's a AS thats for sure. I saw one that asked about a similar one  yesterday.  How does it look on the other side.
So as Rogart63 said, do you have a photo of the other side, and another preferably with the escapement removed?
If HS is all you need,  hairsprings of similair or close physical specification and structural properties can be fitted on. A sample of the HS, a piece left on collet or stud, is the guideline to see what spring is highly likely to vibrate the BW to the right beat, through shortening the HS.
If you got spare HS,  selecting one by comparison is within reach.
Repairman usually perfer to select one with collet already attached and that fit the collet seat on the BW.
This may sound nonsense to you, thats how it was before production advanced and cheap ready to instal complete balances were made available.
Ill get a picture when i get home tonight if i haven't got one on my phone. Thank you for the reply.
It looks like an AS 52 or AS202 but the whole balance plate seems to been replaced with a later part.
Wow, I agree that the top plate bridges look like they’ve been re-fabricated. I can see the similarity of the AS 52/202 calibers. Perhaps as Nucejoe suggested, it might be worth seeing if you can find a similar hairspring that will fit the balance wheel as it’s going to be almost impossible to get an exact replacement.
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
