Loupe / eyeglass / eyepiece
7 hours ago, AndyHull said:
They are pretty useful too I have one in the office.
I think the order of usefulness of different magnifiers goes something like this.
With my naked eye, I can see the watch and tell the time.
With my reading glasses I can appreciate the texture of the dial, and do simple tasks, like fit a winding stem and hands.
With an additional pair of glasses I can lift and re-fit a balance, work with most bridges, align pivots and so forth.
With the illuminated desk magnifier and my reading glasses, and some fine tweezers and a couple of pins I can do more delicate work, like sorting out hairsprings.
With 2 pairs of 3.5 reading glasses (or a head magnifier or better still the 10x loupe) I can examine the general state of the pivots, judge the level of dirt on the jewels.
With my optical microscope at its lowest magnification I can examine the actual wear on the pivots, jewels etc.
With the next stage, I can see the surface detail of the metal finish on individual watch teeth, and the smallest of debris, and globs of gunk trapped between the teeth.
The maximum optical magnification lets me see the structure of the fungal spores on the surface of the dial. :D
... and finally, with my naked eye I can see that this work area is in serious need of a tidy again. :P Fortunately this is generally *not* where I tend to work on the delicate stuff, but I know what my next task is.
Thanks so much Andy
Definitely a great set up in stages of magnification
The microscope is awesome.  I look forward to building up my " magnification station " lol
I guess if you can't see it,  you can't clean it
Or repair it, this really teaches me the  importance of good lighting and magnification
This is one aspect of repair where shortcuts don't help
6 hours ago, m1ks said:
I have a selection of loupes but really only use the 2.5 and 7.5 for closer work and inspection, very very occasionally a stronger one for close detailed inspection.
Thanks m1ks
I'll be getting a 2.5 soon ;)
Atleast will give me around 4 inches of clearance from the work
I have a 10X that I use for inspection
On 3/24/2019 at 10:55 AM, chrisdt said:
http://www.brunelmicroscopes.co.uk/longarm.html
Have a look at these....I'm in the UK but I'm sure I have seen the advertised in the US
Chris,
Thanks - I decided to go with the Long Arm scope option. I just ordered today - so, I don't have it yet, but pretty sure I will be happy with that decision.
I found an AmScope (SM-1BSX-64S) that looked like a good choice. Though would have been nice to be able to look through a number of options first.
BTW - I tried to order something from BHER Optical, but they seem to be out of business. I was able to place an order - but haven't been able to get a response from anyone. So now going through the process of getting my money back.
-Paul
I have the cheap Chinese version with digital screen. It works well for me but I spin the scope 180 degrees so that I'm working off the table rather than the little base. This makes it top heavy so I have a tin of lead shot on the base to balance it.
I usually use an A4 sheet of card with a couple of datum points marked on it to place the job on so that I don't have to move tiny parts around trying to get them under the scope.
Thanks Eezy,
I may flip mine 180 too - will just have to see how well it works as-is.
Definitely looking forward to seeing how well it works compared to the Visor that I have (OptiVisor).
Which, for me, is practically worthless. No working distance - and view is very distorted.
-Paul
Are you referring to something like this eezy? Cordless Digital Microscope
This looks like it might be a useful solution for me, but I can't work out what you mean about spinning the scope 180 degrees. Could you describe this further, or post a pic of your setup?
I currently use a cheap flexible magnifier with led lighting built in, which works okay - but I could do with more magnification and a solution with a screen seems a good way to go.
Yes but mine is this one.
https://www.ebay.co.uk/itm/600X-3-6MP-USB-Digital-Microscope-4-3-Display-LCD-Electronic-HD-Video-Stand-Kit/183572621415?epid=21026543881&hash=item2abdc7e867:g:kdMAAOSwM7Fcqz8d
Using it as in the pic, you are working on the small base area. If you turn the whole lot around as if you are looking at the back and then turn the screen and scope  around to face you, you are not restricted to working on that small base. At that though it will be top heavy so you need to place a counter balance weight on the little base to stop it falling over.
I also work off a piece of yellow card marked with datum lines so I can focus the scope and place tiny parts exactly in the spot under the scope.
If that doesn't help I'll have to set it up and post a pic.
(Nearly forgot to add the pics, video and battery life are excellent. Reckon my battery lasts about 6 hours)
Edited by eezy
Omission
PaulnKC,
I went through the same thing a number of years ago. The device that worked the best for me was definitely a microscope. Low power loupes have a decent range of focus but as the magnification increases the range of focus decreases. At 20X any head movement will throw the watch movement out of focus. Since the microscope lenses are fixed in a frame, you can examine  parts at 40X with no problems. Also, your eyes emit vapor which will fog up the loupe. I would vote for the microscope hands down.
david
Ahh... Yes, now I see what you mean! Thanks very much for taking the trouble to explain that eezy, and for the link too. That's great - I'll get one of those ordered and give it a try. You really can't have too many incoming packages from Ebay in this hobby...
14 hours ago, david said:
PaulnKC,
david
David,
Yeah - I received mine on Friday. I set it up over the weekend and I am thrilled with the results. Very sharp and distortion-free field of view.
I will probably have to set up a separate - lower height - table for the scope though. As the working distance and height of the scope don't match my regular work surface height. But that's not hard to solve. I am just happy that I have a really nice sharp, comfortable view to work with.
The AmScope "SM-1BSX-64S" is a 3.5x to 45x zoom with a nice bright (adjustable) LED ring light. The magnification range can be altered with accessory lenses, but I don't think I'll need to do that.
I can see where using one with screen display would nice. As you wouldn't have to have your  head positioned over the eyepieces. Which means no effect on your seated position or work surface height.
-Paul
PaulnKC
Glad you have found something your happy with. I use mine all the time now and rarely use a loupe. I sometimes wonder if I should have spent a bit more and got an auto zoom. Its ok when the watch is flat everything is sharp and in focus but when you stand the watch on its edge for say removing dial screws you have to wind back the focus. Ive also noticed that when using a loupe click springs fly away and you usually know the direction. Using a microscope they just 'disappear'
Having looked at the advice and solutions here, I'm going to try a slightly different approach and see how it goes. I didn't really want to spend money on a small screen when I have big screen phones and iPads around the place - so I've ordered this wi-fi zoom microscope from Ebay to hook up to my iPad. It's 1080p too, because I noticed that most of the integrated camera/screen combos were low resolution.
When it arrives I'll report back on whether I get it set up so it's a useful tool. If it isn't, at least it'll be something for the grandchildren to play with!
Glad I found this topic as I was going to order some head band style magnifiers. Definitely will be taking a look at microscopes after seeing that a lot are happy with it. I agree, the 'eye height' has to be taken in to affect with different work surfaces. With 10X plus your holding the parts in your hand, or your bending over looking at them on the bench.
I'll post also if/when I find something that works for me. Keep the thread alive, we/I need it!
George,
Glad that you found it useful.
I am with you - I think this is important info. I wish that I had found this before I purchased my visor.
-Paul
On 3/24/2019 at 6:18 PM, PaulnKC said:
Wow - I would never have thought of that. I will have to investigate this (if I don't find something more "off the shelf" first)
The point is, our eyes can adapt to the eye piece, regardless of our best option.
Even if we personally try the loup prior to purchase, our decision would be based on the information at our brains disposal at the time. Specialists know more than we do about eyes, what little feedback specialist get from us is not neccessarily correct. Try it at home, imropve our feedback.
 You emphasised having weak eyes while seeking advice. So I recommended investing in your eyes first , tools come next. Best wishes joe
So just to quickly update this conversation with my own experience to date. I got the wireless connecting microscope I mentioned above, and... It'll make a neat toy for the grandkids. The picture is pretty bad, with a lot of edge chromatic aberration due to the plastic optics. And the small options for setting the device resolution mean that the picture is out of whack on an iDevice, due to them not having standard HD resolutions. Obviously you get what you pay for - and this is essentially a toy.
I'm inclined to just practice more with and get used to wearing a headband magnifier (I wear glasses, so need something that caters for them). Can anyone recommend a good model of the headband variety? Again I went for the cheapo option when I bought one, and it's both uncomfortable and quite flimsy (the hinged lens holder has a habit of swinging loose at critical moments...)
Invest what in my eyes?
I have spent at least tens of thousands of dollars on my eyes and their medical and optical attention over my lifetime - thus far.
I don't have weak eyes - I have poor eyesight. Main issue is nearsightedness. Also some astigmatism in each eye. Now, being well over 50, I have some farsightedness on top of the stuff I was born with.
I'm not complaining - LOTS of people have the same issues. Including (I suspect) lots of folks on this forum.
What exactly do you mean when you say invest in your eyes?
-Paul
-Paul
Ah - now I see what you referring to. I didn't connect your most recent post with your earlier suggestion about using dental/medical/commercial eye-ware. My apologies. It had been too long since - at least for me to remember.
I still think that's a great idea.
Having said that - I am really happy with the long-arm microscope solution.
Hi All - I started making a newbee tool list, learning from others like Davey57 who upgraded to the next level without going overboard and wished he had made the jump to “better” tools from start. Dave help me in choosing screwdrivers and tweesers - Thx Dave!
I am looking for loupe(s) with a nice glass. From experience in another hobby, I learned a nice less magnified glass is better than a lesser glass quality at higher magnification.
Read about B&S, Bergeon, ASCO,  Horotec and others brands. Which loop has the best and clearer less distortion glass from edge to edge ?
Lastly, and maybe I should create a new topic for this one, which better quality tools (Brand and model) you wish you had purchased before going for lesser quality as a newbee ?
Thank you for your input ... AJ
13 minutes ago, Tmuir said:
I have several Bergeon loupes and I'm happy with all of them unlike the cheap Anchor ones I originally bought which where crap.
That means they are genuine unlike the fake one that the tools guy sold me at the HK fair, pure crap worse than Anchor. I have the link for an alternative not expensive one from Switzerland but never got the will to get it after all, I really should.
Edited by jdm
@Tmuir: I appreciate your input. Will look into Bergeon more closely.
@jdm: Could you omease post link for Swiss loupe alternative. May it could help me and others as well.
Does anyone have Horotec loupe experience ?  I understand they are more expensive but from experience, good glass does not come cheap and is certainly worth the comfort and definition it brings. Also better for eyesight, not having to squint :)
Thank you... AJ
Edited by ajdo
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
