NEED HELP - Bergeon 5700-BP
Apocalypto
Hi everyone I am interested to buy Bergeon 5700-BP.
But before I buy it I need to see if someone can answer my questions, as I tried to contact bergeon itself but no response...
Anyone have it or can help me if this type of tool opens the most tightened back pressure cases and that can reach the back lip that sometimes its in the corner of the bezel and that it can open those that don't have back lip (Like Tissot / Longinges etc..)
I appreciate if someone can give me some advice before I buy it please.
Thanks,
Steven
I have one albeit the Chinese version. It will open any screw back watch case. Mine came with a set of milled edge adaptors for opening Rolex cases. I use it mainly for opening really tight cases because it has a locking wheel for maintaining downwards pressure. Especially useful when the gasket has degraded to a glue like substance. It obviates the risk of your watch looking like someone has opened the back with a chisel. I have mainly sixties and seventies Tissots on which it works well (except of course the Seastar Seven) The only down side is that its rather large being nearly 1 foot in height (30 cm) and the wheel at the top is like the steeing wheel from a pedal car being 6 inches in diameter (15cm) How it compares with the Bergeon version I'm not sure but what the hell its for taking case backs off. I wasnt about to remortgage for the sake of Bergeon. If you have a good set of basic tools then go for it.
Thanks for your help but 5700-BP is a different tool its not like 5700-Z. The one I am talking about is to open the pressure back cases (snap on) not screw back cases.
Thanks,
Steven
I think few people have bought this tool...
On 3/25/2019 at 1:53 AM, jdrichard said:
I don’t think so. You need to pry these open.
The problem with prying manually is that as soon the tool slips - and on tight cases it does, you've got a scratch. That isn't acceptable.
Some members here got an affordable Chinese tool and I think I'll get one too. There is also another hinged type, but it's all plastic and I would not recommend it.
07115-Watch-Back-Opener-Tools-Watch-Snap
Edited by jdm
07115-Watch-Back-Opener-Tools-Watch-Snap-on-Case-Back-Opener-for-Prizing-Watch-Bottom-Cover.jpg&key=0404f288c7c1932232bb5b9f56ebce188462ebaabb0441b913d038041856cb67
I have not scratched one yet, but I can see your point. Will the Subject tool work to remove a snap on case?
Yes, this will remove a snap back case. One of the chisel points is extremely fine. If you should ever have a case that is too tight for the fine point to enter, just tap a single edge razor blade into the slit and that will open it enough. The tightest watch I've ever opened was a Bulova dress watch and this tool opened it with ease. It's also good for removing bezels.
I didn’t think I needed to buy yet one more tool, however......
In the grand scheme of things, a tool is less expensive than ruining a good watch. Mine is a Horotec knock off produced by a Pacific rim country. The center post is fully adjustable as it is spring loaded so you can easily move it to the correct position. I purchased mine on evil bay for about $40 USD.
I guess you mean Chinese? Is it the same in picture? Nothing wrong with posting links here as long is not blatant advertising.
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
