Movado Subsea Chronograph
Here's a couple of Movado Subsea Chronographs from the 1950's that are just about twins.  The one on the right (#1) has had a bit of a hard life compared to the one on the left.  Gone are the Kris hands from the minute and hour registers.  The original crown is missing too and it appears that the pendant tube was modified to make the new crown fit (see bottom pic).  It's a terrible shame as this is a Taubert/Borgel case and of high quality craftsmanship.  The outer end of the pendant tube has been lost (perhaps filed off) and the cork gasket is long gone.
The Subsea on the right (#2) is in better shape with the original Kris hands, crown, and a movement that appears to have been serviced recently. The lead caseback gasket is gone and replaced with a rubber one and the larger hands are clearly wrong- why have luminous paint on the dial if the hands have none?
The trick here will be to bring both watches back to Movado factory specifications.  I doubt I can locate the Kris hands but if anyone knows where I can find a proper Borgel style crown and is willing to share the info that would be greatly appreciated!  I picked up an old Mido Multifort which has a similar crown but it would be a shame to steal parts from it as it's otherwise complete.
I've dug through my vintage hand drawer and think I might have the proper hour and minute hands needed for #2.
I wonder if there are there any thoughts on how I could go about fixing the pendant tube on #1?  The backup plan will be to just leave it as it is- the watch is vintage and replacing the cork gaskets in the pusher tubes to a level that will ensure reliable water resistance is probably not possible (I don't have the tools and I don't believe replacement cork gaskets can be found). I do love to do restorations though... Any thoughts/suggestions are appreciated.
Thanks!
Thanks!
I'm sorry I don't have any leads on your request Ry. Are these column chronos an in-house? The movements are beautiful.
J
J
Thanks- I'm sure one will show up in time.  ;o)
Yes, the movements are in-house column wheel chronographs; you might know I'm trying to work my way through all of the manual chronographs of the golden age!  They're quite nice though- they do look better in person but feel better than any other watch I've had thus far. Movado made some keepers back in the day.
Thanks!
   i ave one of these movado's,  seems to me it has a lead case gasket.  vin
You're working your way through ALL the chronographs?!? Man, I wish I had time to even do the top three. My experience thus far is limited to 7750 and one Landeron cal 2. I'm looking for a birthday year watch and was leaning towards valjoux 7733 or Omega's lemania-derived 861-1863. Thoughts?
J
J
Yeah, I'm not really sure what even got me started on the path; I guess I just like seeing the different solutions each manufacturer had for the same problems.  It's a hobby though so time is on my side. ^_^
I have an affinity for Venus movements (which the 7730 is derived from) but the 861 is considered by some as the best manual wind chronograph out there. I'm not aware of any weaknesses in the movement.  Also, if you don't have one already, it's a good excuse to get an Omega Speedmaster.  Hamilton has some great 7730 chronographs too.
I like the way you think! I'm looking for an Omega now, and I like the Speedmaster Broad Arrow reissue with the plexi and caliber 1861.
J
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
