What about Bergeon Clip On Spectacles?
VWatchie
I need some magnification advice. I’m considering these Bergeon “Clip-On-Spectacles” as I wear glasses. So far, I’ve only used cheap Chinese magnification glasses from eBay, and I’ve been happy with them as they give me a stereo vision (never really liked to look with one eye only). However, it is a constant hassle to switch between my ordinary progressive glasses and my Chinese magnification glasses. So that’s mainly what motivates me. Come to think of it; perhaps progressive glasses combined with a clip-on is a bad mix? Perhaps it would be better to use a pair of reading glasses with a clip on?
I’m right-handed and I'm right-eyed, so am I correct to assume that I should go for the right-eyed version of the “Clip-On-Spectacles” to make room for screwdrivers and tweezers? Seems obvious but I want to make sure. What magnification would be the most convenient for working with screwdrivers and tweezers on a movement? The focal length for a 10 power magnification is just an inch, so I assume my head would then bump into my tools. I have a stereomicroscope (20X/40X) that I use when I need to get really close. The focal length of the 5 power clip-on is two inches, perhaps still too close? What is your experience, and what level of magnification would you recommend (10.0, 6.7, 5.0, 4.0, 3.3, 2.8, or 2.5)?
Edited by VWatchie
typos
Hi Vw   they look somthing like this , these have muliple lenses easily worn over glasses and hinge up over your head out of the way
Does anyone use a microscope? Im new to this hobby but i repair electronic equipment under x10 barlow magnification for solder work & have been tinkering with watches of late. I have a few types of magnification glasses like the one pictured above and im finding the microscope being way more practical for me.
Sent from my SM-G950F using Tapatalk
I have a huge collection of magnification products that I have tried, including dentist Bono’s, eye pieces, traditional flip down eye pieces (not cheap). I eventually bought 3.0 reading glasses and added a clip on loop at x2 power for general close work and x10 clipon loop when I work in the Lathe. The good thing is both my eyes are protected when using my Lathe. The clip on flipdown loop is the best and fastest.
Oh ok i didnt consider lathe work, i knew you guys all wear spectical type magnification for a reason.
Do you use a watchmakers lathe. If so you will be looking at, perhaps, a small balance staff while cutting it and need to protect the other eye that will be open.4a0ea1af43c83ab8892a112aea220775.jpg
Do you use a watchmakers lathe. If so you will be looking at, perhaps, a small balance staff while cutting it and need to protect the other eye that will be open.4a0ea1af43c83ab8892a112aea220775.jpg&key=b07daccc8ef4871fc4275eda294485539b57602a8e1913813bce1d92789dcab2
No i dont JD, looks like an awesome setup you have there. If i require delicate machine work ill know who to pm though [emoji1360]
Once you go down the toad of making balance staffs, stems and crowns; and repairing pivots and a million other thinks, it’s a whole different study and also cost. Tools and collets and gravers and books and videos and and and and:)
Lol i could only imagine mate, im not sure if im going to go that deep in the rabbit hole just yet [emoji1787] sorry for high jacking OP & taking this a bit off topic too.
I can see you're wearing the eyeglass on your left eye. Is that because you're left-eyed or because it's more convenient when you do lathe work? The Bergeon clip-on that I'm considering comes in left-eye and right-right versions so I need to get this right for the work I do when assembling/disassembling movements using tweezers and screwdrivers (no lathe work, yet), and as I mentioned I'm both right-eyed, and right-handed and I fear that if I get the wrong version I will end up in an awkward working position.
And what would be a good level of magnification? Or perhaps a more relevant question is; what would be a tolerable focal length to make room for my head, tweezers and screwdrivers?
10 hours ago, watchweasol said:
Hi VW  for general work I wear a head set with a full binocular vision over my glasses It has a lift up front which contains  two lenses, for close work I have to remove my glasses and use the double lens on my left eye, If I can find a picture of them I will post it.
Thanks for the tip! However, I've already tried this and I'm afraid I found it too bulky for my needs.
Oh yes, I just couldn't live without my 20X/40X stereomicroscope! I use it when oiling jewels holes, pallets, etc. (to me it offers a much higher level of precision), and when I need to understand what I'm actually looking at (dirt, debris, discolouration, rust, and so on). The only inconvenience is that the design om my scope is such that I need to move the part under it, rather than bringing the scope to the part, and of course, I can't move my head around the part. If interested I wrote more about it in this thread. Anyway, for disassembly/assembly of watch movements, the scope isn't all that convenient, except for things like setting anti-shock springs.
I don't wear glasses but I'll add that I use a 3x loupe (right eye, right handed) for general bench work, and use a zoom microscope for inspection and oiling. Around here the glasses wearers tend to take them off and use a conventional loupe but that may be due to their particular eyesight. I know others who use the clip on loupes and are happy.
For general work anywhere between 2.5x and 4x is ok. Going above, even 5x, can be very tiring for the eye. The high power loups are more for inspection use or short duration.
For lathe work I have a scope mounted over it that gives 10x or 20x. 10 for most stuff, 20 for really fine work.
No issue at all.
Where did you get the scope for lathe work? Any pictures?
VW i have read your other thread and it seems this has been an issue for you for quite some time. Other members have commented on using microscopes for lathe work which could be an option later down the road if you decide to get into lathe work too. Here is my stereo microscope setup for mother board work and i can work under it for hrs at a time with no eye strain. You can see the makeshift stand that i made for it,which was only intended to be temporary untill i purchased a boom stand but never did. I can zoom out of work to get a full view of a movement and also zoom in to see jewel holes too. The working clearance is about 6- 8in so there is no issue getting tools under it to do work. I payed $100 for the scope 2nd hand from ebay and an extra $40 for the widefield x10 barlow to get away with it on the cheap. Alternatively (AM scope) have awesome gear used in the micro solder work industry which you could have a look at if you are interested. Attached is pics of my gheto setup boom stand and the zoom range of the scope at that hight.8191a8d29bc0ed14d3ff4f3d92045381.jpg4f2fb8f308edd43b529c45177962b0f0.jpg7e63729be8926796f7bb24242adf4c87.jpg
VW i have read your other thread and it seems this has been an issue for you for quite some time. Other members have commented on using microscopes for lathe work which could be an option later down the road if you decide to get into lathe work too. Here is my stereo microscope setup for mother board work and i can work under it for hrs at a time with no eye strain. You can see the makeshift stand that i made for it,which was only intended to be temporary untill i purchased a boom stand but never did. I can zoom out of work to get a full view of a movement and also zoom in to see jewel holes too. The working clearance is about 6- 8in so there is no issue getting tools under it to do work. I payed $100 for the scope 2nd hand from ebay and an extra $40 for the widefield x10 barlow to get away with it on the cheap. Alternatively (AM scope) have awesome gear used in the micro solder work industry which you could have a look at if you are interested. Attached is pics of my gheto setup boom stand and the zoom range of the scope at that hight.8191a8d29bc0ed14d3ff4f3d92045381.jpg&key=2a8f1db94293d49d94574e188a2849b66879ac10c1d67cbd251acb90692675114f2fb8f308edd43b529c45177962b0f0.jpg&key=5e7751efaaade5026d80347e6376eac82fa6661e7fb29d25df314a5109cca3b47e63729be8926796f7bb24242adf4c87.jpg&key=68345e6aa7c7431797d10c288f6831a957788b7440ba52611c31cc73e98fe782
Thanks and good setup. This might work for cutting balance staffs
I found this scope in a flea market. It's an Olympus, I like it because the head is quite compact. The base of my lathe had a gooseneck lamp that I removed, and I cobbled together the vertical support and mounted it there. It swivels out of the way in an instant. Before this I had a similarly compact old Leitz on a stand, there are lots of single or dual power small stereo scope heads out there, often with boom stands already which make them basically ready to go for watch lathe work. I have been using a scope over the lathe since I finished school 20 some years ago, I don't think I could work without it.
This seems like a very good setup. I do have an issue with the portability of my Lathe setup as I use the same desk for watch work and for work work. A problem I need to resolve by buying a bigger house:)
    • Yes I have that in my watch list a JUF if cheap enough I will have a go , if nothing else it will be good for spares, I have a few JUF’s
    • Less give a damn- more **BLEEP** it! …nice that it is keeping time I’ve done a couple of these (one with your assistance) and there’s a third that needs work on the tension between what drives the hands and the barrel. Did you have any issue with that? …and I saw Ranfft make a small comment in a thread re: pin pallets- a couple drops of Tillwich blu, let it run down the pins. It is good for 20 degrees of amplitude… I’m using this oil as a cheat code on my unmotivated Venus chrono…
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
