Watch Repair Course
Just finished the Level 3 Watch repair course and it was great. Tons of great information and excellent instruction by Mark. Scored well too. Can’t wait for the Level 4 Course just to see it I’m doing it right. Great tips throughout the course as well.dd3b7c5cacb797629e8982081453965f.jpg
Please allow me to add my voice to the chorus of congratulations. Regardless of your motivation, as we say here in Texas, "If you can actually do it, then it ain't bragging to say so". Your posts are always a welcome read.
Thank you Mr. TexasDon. Please check out all the videos I have made on YouTube trying to help folks with watch repair. I am not an old hand at this but I have read most the books and have worked my buns off over the past 6 years trying to get better at this skill. Search under JD Richard it jdrichard01
  • 5 weeks later...
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
