Watch Repair Course
Just finished the Level 3 Watch repair course and it was great. Tons of great information and excellent instruction by Mark. Scored well too. Can’t wait for the Level 4 Course just to see it I’m doing it right. Great tips throughout the course as well.dd3b7c5cacb797629e8982081453965f.jpg
Please allow me to add my voice to the chorus of congratulations. Regardless of your motivation, as we say here in Texas, "If you can actually do it, then it ain't bragging to say so". Your posts are always a welcome read.
Thank you Mr. TexasDon. Please check out all the videos I have made on YouTube trying to help folks with watch repair. I am not an old hand at this but I have read most the books and have worked my buns off over the past 6 years trying to get better at this skill. Search under JD Richard it jdrichard01
  • 5 weeks later...
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
