Bulova 6CF Movement
The 6CF I have will work as long as pressure is applied to the stem, as in winding pressure - it need not actually be turned.
The pallet fork moves fine and the balance wheel is fine when it is replaced without the pallet fork being in place.
The watch wants to work. I just don't know where the problem lies but there is some friction somewhere.
Maybe the mainspring is shot.
The watch has been cleaned, lubricated and winds fully. The mainspring might just be very weak.
It's a bit of a mystery why it doesn't run. The impulse jewel is between the banking pins and the regulating mechanism doesn't seem to be the problem.
Either there is too much friction somewhere - I have no idea where - or the mainspring just isn't strong enough to keep it running.
I find it strange that it runs when I keep winding pressure on the mainspring.
My guess would be friction on the barrel arbor pivots or a weak mainspring. I know the symptoms you mention, I have an HMT that exhibited those and winding fully would get the balance moving lethargically briefly then stop. Then holding winding tension got it swinging and it eventually continued but the amplitude is low. That will get stripped, cleaned and checked at some point.
It's about 99.99% not a mainspring issue. It should limp along with a 5x weaker spring- poorly but running. Is the train free with the balance and fork out? Like two clicks of wind, train should run and escape wheel should turn backwards at least a little at the end. With just a few clicks of wind the fork should snap back and forth cleanly. With fork out and balance in, balance should oscillate freely and for quite some seconds with a swift twist of the movement. If these things aren't happening then start checking methodically.
Going back to the barrel- it could be an issue: when you assemble it you should hold the assembled barrel between stout tweezers on the ends of the arbor and check for endshake. Make sure the cap is fully seated. Make sure the holes in the plate aren't too worn (often an issue with seiko). But even if all that was wonky it should 'run', at least poorly, with a couple of turns of wind.
It can be very difficult to observe the effects of wear in the barrel arbor bushes. This can cause the barrel to cant over and significantly increase the friction in driving the next wheel in the train.  This will not happen without tension in the spring, but you can see how much play there is when the spring is unwound.  Wear could be in the barrel or the movement plate/barrel bridge.  In the latter case you sometimes have to look at the plates from the inside as the wear can be below the edge of the oil sink.
6 hours ago, yankeedog said:
Agreed.with the balance and pallet assembly removed the watch should spin.even with a weak mainspring.
It does. I've removed the balance and the pallet fork and it spins with no problem with only one turn of the crown.
The pallet moves back and forth and the balance is free. I'll check the barrel for wear.
One turn of the crown or one click of the ratchet wheel? It should spin the gear train with one or two clicks. With a few clicks the fork should snap back and forth with a little nudge.
But imagining one turn of the crown turns the train the watch should still run. If it's even just close to being in beat, the balance is free, the fork is working correctly*, and the train is free, the watch really should run with just a bit of winding.
Check with balance and fork in, power down, see that the balance swings freely while engaging the fork. It may stutter a bit as the fork knocks into the escape wheel, that's normal.
*Perhaps the escapement is grossly out of adjustment but still "snaps" when manually advanced.
Thank you both for your input.
I will check the hairspring again. It was messed up and I had to untangle it but it was flat, evenly spaced and centred on the balance cock before I put it back on the balance staff. I'll check it again but i really hope it's OK. Working on it under a microscope with fine tweezers isn't my favourite thing to do.
18 hours ago, yankeedog said:
Brain surgery is probably easier.
Funny you should say that. I was on a watch factory tour and one of the companies held a master class in watchmaking for us. The guy next to me had been a brain surgeon and he was losing screws left and right. He turned to me and said, “I’m sure glad my former patients aren’t watching me do this.
 I’m not at home just now so I’ll let you know what happens.
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
