Starting aNew Balance Staff
Fixing a friends dad’s old Waltham and it needs a new staff. Step 1 is to remove the balance cock.4bd545f2041eaab967d5cdae2548d075.jpg
Step 2 is removing the balance with the roller table and hairspring attached.6233332f4638a270ba54754ea34a8898.jpg
Step 3 is removing the hairspring. Then have a look at the good pivot. It will provide a good reference to measure for the new pivot.
Step 4 is to remove the roller table. Lots of different tools and techniques here but I have an old factory tool.
e9c12aab08acfa6998c828f63e6367b2.jpgfae28e6171839ea95d6f805a484c2efc.jpgefc2f91fd7fdd90957bf61097913cb13.jpg
Step 5 is to cut off the old riveted balance away from the staff, on a lathe.094e0b1450385c09a76ad4e5c1bee599.jpgd008ac44b7943acbd90e966e5347bd41.jpgbb312e72455e54ff6255f04159db15ba.jpg
Step 6 is to punch out the old staff from the balancea61d5643c9897975077f1498f081906e.jpgbcfeb5e5c9248816daff16bdcf7b9448.jpgStep 7 is to measure the old balance staff09f3e8318bf7518718c56bdfc2887c1f.jpg9767263377f29398f5d223be6b948014.jpg09870f2276e9a0dcfc0e31713806d65e.jpgThen you prepare a piece of blued steel for the Lathe to cut the new staff.
1 hour ago, oldhippy said:
You are growing in confidence in making new staffs. Nice photos so members can see what you do.
Hi Jd ,  I imagine you remove material from collet seat and inside of riviting shoulder perhaps dril a hole inside the balanace shoulder,( I think I saw it on marks video) to punch the riveted portion of staff out.
Punching the rivted shoulder and the pivot and everyrhing else out with a sldge hammer is widely practiced. Do you see the difference worth the work?
You can punch the staff out with the tool I show in the picture locked into the Staking Tool. It will remove the riveted portion, but there is a chance you will distort the hold of the balance staff or even warp the balance arms. So that is why the best technique is to use a lathe. Not sure what you mean about drilling a hole. As well, you need the old staff to make the new staff for dimensions or you will have to figure out the staff dimensions the hard way.
Hi , What tools do I need to measure dimentions on a staff?
I have a lot of obsolete staffs, some are mixed which I like to identify.
Here is a diagram for common language . Thanks    joe
For general measurements I use the following gauge c302e52f144a07a626e598ba76c17c67.jpg
You could also use a micrometer
Well done. You could make yourself a tidy sum if you advertised that you make balance staffs.
You may be correct. Done and installed and works well.02ca2c796c2a2cd69bee03b3b39443b8.jpg45057f85755f1eef6ddd5cd8218d4c6d.jpg40e694431db9544e4bce7e546884d8e9.jpg
And then I found a bad Upper Jewel and had to trim a setting I had that almost fit. Used jeweling Collet in 50mm chuck with a 2mm flat graver and got us down to size. Pivot needed a bit more adjustment.08d83ff912533186a87c5aa87570b437.jpg1bd37921c397fc7517c057c4b5f07272.jpg26a330caed77a501801adcc764b25168.jpgf7444e96d2c02cea7de1579237ea08fc.jpgd6c352768912796354219ac8c66f571a.jpga889caf5e0979d652ad6f8000c9e5046.jpg9237d6366f913af00296c84155ebcf68.jpge6c4cf1172ebb31568d1a81fb8048f40.jpg
Done and dusted. The movement has a bad mainspring so I installed the balance and put a small push on the center wheel and the balance came to life:)9072f788199f7394671f1aad4d7bc8cc.jpg
  • 4 months later...
Brilliant !. Not that i can afford a Lathe at present, or wether i could even do such a task, but the satisfaction of doing such a perfect job, must be very pleasing. With hard to impossible to find staffs, for older watches, its the perfect part of learning.
I don,t make staffs and be happy to just staff a BW with ready factory made ones of known caliber. Dosn,t removing the rivited portion of the old staff on lathe reduce the risk of warping the wheel?
You are correct. Four months of study and trial before I cut my first staff. Had never used a lathe before or understood how to cut properly. Did a lot of hours of practice. And also bought the two video training sessions from Trop and Tasconni.(spelling may be off)
It does and I have used the lathe technique for other staffs that had a rivet
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
