Starting aNew Balance Staff
Fixing a friends dad’s old Waltham and it needs a new staff. Step 1 is to remove the balance cock.4bd545f2041eaab967d5cdae2548d075.jpg
Step 2 is removing the balance with the roller table and hairspring attached.6233332f4638a270ba54754ea34a8898.jpg
Step 3 is removing the hairspring. Then have a look at the good pivot. It will provide a good reference to measure for the new pivot.
Step 4 is to remove the roller table. Lots of different tools and techniques here but I have an old factory tool.
e9c12aab08acfa6998c828f63e6367b2.jpgfae28e6171839ea95d6f805a484c2efc.jpgefc2f91fd7fdd90957bf61097913cb13.jpg
Step 5 is to cut off the old riveted balance away from the staff, on a lathe.094e0b1450385c09a76ad4e5c1bee599.jpgd008ac44b7943acbd90e966e5347bd41.jpgbb312e72455e54ff6255f04159db15ba.jpg
Step 6 is to punch out the old staff from the balancea61d5643c9897975077f1498f081906e.jpgbcfeb5e5c9248816daff16bdcf7b9448.jpgStep 7 is to measure the old balance staff09f3e8318bf7518718c56bdfc2887c1f.jpg9767263377f29398f5d223be6b948014.jpg09870f2276e9a0dcfc0e31713806d65e.jpgThen you prepare a piece of blued steel for the Lathe to cut the new staff.
1 hour ago, oldhippy said:
You are growing in confidence in making new staffs. Nice photos so members can see what you do.
Hi Jd ,  I imagine you remove material from collet seat and inside of riviting shoulder perhaps dril a hole inside the balanace shoulder,( I think I saw it on marks video) to punch the riveted portion of staff out.
Punching the rivted shoulder and the pivot and everyrhing else out with a sldge hammer is widely practiced. Do you see the difference worth the work?
You can punch the staff out with the tool I show in the picture locked into the Staking Tool. It will remove the riveted portion, but there is a chance you will distort the hold of the balance staff or even warp the balance arms. So that is why the best technique is to use a lathe. Not sure what you mean about drilling a hole. As well, you need the old staff to make the new staff for dimensions or you will have to figure out the staff dimensions the hard way.
Hi , What tools do I need to measure dimentions on a staff?
I have a lot of obsolete staffs, some are mixed which I like to identify.
Here is a diagram for common language . Thanks    joe
For general measurements I use the following gauge c302e52f144a07a626e598ba76c17c67.jpg
You could also use a micrometer
Well done. You could make yourself a tidy sum if you advertised that you make balance staffs.
You may be correct. Done and installed and works well.02ca2c796c2a2cd69bee03b3b39443b8.jpg45057f85755f1eef6ddd5cd8218d4c6d.jpg40e694431db9544e4bce7e546884d8e9.jpg
And then I found a bad Upper Jewel and had to trim a setting I had that almost fit. Used jeweling Collet in 50mm chuck with a 2mm flat graver and got us down to size. Pivot needed a bit more adjustment.08d83ff912533186a87c5aa87570b437.jpg1bd37921c397fc7517c057c4b5f07272.jpg26a330caed77a501801adcc764b25168.jpgf7444e96d2c02cea7de1579237ea08fc.jpgd6c352768912796354219ac8c66f571a.jpga889caf5e0979d652ad6f8000c9e5046.jpg9237d6366f913af00296c84155ebcf68.jpge6c4cf1172ebb31568d1a81fb8048f40.jpg
Done and dusted. The movement has a bad mainspring so I installed the balance and put a small push on the center wheel and the balance came to life:)9072f788199f7394671f1aad4d7bc8cc.jpg
  • 4 months later...
Brilliant !. Not that i can afford a Lathe at present, or wether i could even do such a task, but the satisfaction of doing such a perfect job, must be very pleasing. With hard to impossible to find staffs, for older watches, its the perfect part of learning.
I don,t make staffs and be happy to just staff a BW with ready factory made ones of known caliber. Dosn,t removing the rivited portion of the old staff on lathe reduce the risk of warping the wheel?
You are correct. Four months of study and trial before I cut my first staff. Had never used a lathe before or understood how to cut properly. Did a lot of hours of practice. And also bought the two video training sessions from Trop and Tasconni.(spelling may be off)
It does and I have used the lathe technique for other staffs that had a rivet
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
