Starting aNew Balance Staff
Fixing a friends dad’s old Waltham and it needs a new staff. Step 1 is to remove the balance cock.4bd545f2041eaab967d5cdae2548d075.jpg
Step 2 is removing the balance with the roller table and hairspring attached.6233332f4638a270ba54754ea34a8898.jpg
Step 3 is removing the hairspring. Then have a look at the good pivot. It will provide a good reference to measure for the new pivot.
Step 4 is to remove the roller table. Lots of different tools and techniques here but I have an old factory tool.
e9c12aab08acfa6998c828f63e6367b2.jpgfae28e6171839ea95d6f805a484c2efc.jpgefc2f91fd7fdd90957bf61097913cb13.jpg
Step 5 is to cut off the old riveted balance away from the staff, on a lathe.094e0b1450385c09a76ad4e5c1bee599.jpgd008ac44b7943acbd90e966e5347bd41.jpgbb312e72455e54ff6255f04159db15ba.jpg
Step 6 is to punch out the old staff from the balancea61d5643c9897975077f1498f081906e.jpgbcfeb5e5c9248816daff16bdcf7b9448.jpgStep 7 is to measure the old balance staff09f3e8318bf7518718c56bdfc2887c1f.jpg9767263377f29398f5d223be6b948014.jpg09870f2276e9a0dcfc0e31713806d65e.jpgThen you prepare a piece of blued steel for the Lathe to cut the new staff.
1 hour ago, oldhippy said:
You are growing in confidence in making new staffs. Nice photos so members can see what you do.
Hi Jd ,  I imagine you remove material from collet seat and inside of riviting shoulder perhaps dril a hole inside the balanace shoulder,( I think I saw it on marks video) to punch the riveted portion of staff out.
Punching the rivted shoulder and the pivot and everyrhing else out with a sldge hammer is widely practiced. Do you see the difference worth the work?
You can punch the staff out with the tool I show in the picture locked into the Staking Tool. It will remove the riveted portion, but there is a chance you will distort the hold of the balance staff or even warp the balance arms. So that is why the best technique is to use a lathe. Not sure what you mean about drilling a hole. As well, you need the old staff to make the new staff for dimensions or you will have to figure out the staff dimensions the hard way.
Hi , What tools do I need to measure dimentions on a staff?
I have a lot of obsolete staffs, some are mixed which I like to identify.
Here is a diagram for common language . Thanks    joe
For general measurements I use the following gauge c302e52f144a07a626e598ba76c17c67.jpg
You could also use a micrometer
Well done. You could make yourself a tidy sum if you advertised that you make balance staffs.
You may be correct. Done and installed and works well.02ca2c796c2a2cd69bee03b3b39443b8.jpg45057f85755f1eef6ddd5cd8218d4c6d.jpg40e694431db9544e4bce7e546884d8e9.jpg
And then I found a bad Upper Jewel and had to trim a setting I had that almost fit. Used jeweling Collet in 50mm chuck with a 2mm flat graver and got us down to size. Pivot needed a bit more adjustment.08d83ff912533186a87c5aa87570b437.jpg1bd37921c397fc7517c057c4b5f07272.jpg26a330caed77a501801adcc764b25168.jpgf7444e96d2c02cea7de1579237ea08fc.jpgd6c352768912796354219ac8c66f571a.jpga889caf5e0979d652ad6f8000c9e5046.jpg9237d6366f913af00296c84155ebcf68.jpge6c4cf1172ebb31568d1a81fb8048f40.jpg
Done and dusted. The movement has a bad mainspring so I installed the balance and put a small push on the center wheel and the balance came to life:)9072f788199f7394671f1aad4d7bc8cc.jpg
  • 4 months later...
Brilliant !. Not that i can afford a Lathe at present, or wether i could even do such a task, but the satisfaction of doing such a perfect job, must be very pleasing. With hard to impossible to find staffs, for older watches, its the perfect part of learning.
I don,t make staffs and be happy to just staff a BW with ready factory made ones of known caliber. Dosn,t removing the rivited portion of the old staff on lathe reduce the risk of warping the wheel?
You are correct. Four months of study and trial before I cut my first staff. Had never used a lathe before or understood how to cut properly. Did a lot of hours of practice. And also bought the two video training sessions from Trop and Tasconni.(spelling may be off)
It does and I have used the lathe technique for other staffs that had a rivet
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
