Seiko 6139 pusher and case tube problem
Hi,
I'm in the process of restoring a Seiko 6139-6012. Everything has gone well so far (this being my first chronograph) apart from this problem. One of the pushers was stuck in the case. After a couple of weeks of alternating soaking in WD40 and rust remover I went for the brute force approach, and the case tube (pendant tube?) came out with the pusher still stuck inside it. At this point I could see that the pusher itself was beyond saving due to the amount of corrosion, so the aim is to get the pusher out without damaging the case tube. I removed part of the pusher button (with a file) to allow better access to try and scrape away the rust between the pusher and the tube with a pin. But this is only going to get me so far, and I'm worried about damaging the tube.
I have searched for a replacement Seiko tube without success, and checked the generic pendant tubes at Cousins but none have the right dimensions.
Here's a photo of the pusher stuck in the tube (next to the other, healthy, pusher):
and from the service manual:
Any advice appreciated.
I find it interesting that the drawing doesn't show the C clip that secures the pusher in the tube.
If you can drive the remains of the pusher out, you might be able to reuse the tube by driving it back into the case with a bit of Loctite or JB Weld.
As Rymoeller says you could probably push the old pusher out and reuse the tube. If that fails an old case could  help you out. Have some  badly polished ones that could be used as donor cases.
And RyMoeller there is no C-clips  on the 6139 . The pushers are hold in by the  movement ring.
Ah okay- I second look at the diagram shows the holding ring securing the pusher. :)
As you've probably guessed - I haven't fiddled with a 6139... yet.
Edited by RyMoeller
grammar
How exactly do I push the pusher out? Bear in mind that I spent 2 weeks trying to get the pusher out by every non-destructive means possible until I decided to sacrifce the pusher by gripping it with a pair of pliers very hard and pulling with almost all my strength while the case was in a vice- and then the part which gave out was the case/tube interface not the tube/pusher interface.
What i meant was that to take the tube from a  polished case i have and put back in your case. If you have the sizes i can knock one out .
Have you tried to heat it? And you need an anvil or something to put the tube in  to be able to knock the old pusher out.
Sorry I didn't understand you the first time- yes that would be great! I do have the dimensions, I'll post them shortly.
I have tried heating it, freezing it, ultrasonicing it, bicarbonate of soda, vinegar, phosphoric acid, super glue, a massager (yes a massager)...
UPDATE:
New case tube installed, + replacement (Seiko) pusher. Movement holder finally arrived from Australia, watch finished and working perfectly (+ 1 spd on the wrist). Massive thank you to Roger for his help.
The photo is not very flattering- the hands look cleaner in normal light.
  • 4 years later...
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
