Ebay again
oldhippy
This is listed as a Skeleton Clock. It is nothing of the sort. It looks like a movement that has been taken out of its case and covered with a dome. The movement is not that good it has an open mainspring and a cheap platform.
https://www.ebay.co.uk/itm/273761738048?ul_noapp=true
Here is a proper Skeleton Clock timepiece with passing strike. Passing strike means it strikes 1 on  the hour every hour.
I saw that and thought to myself 'sticking a cheap movement under a dome does not a skeleton clock make. There's another seller who has done a similar thing but has removed a lot of the frame. it looks nice but not a skeleton. I think he refers to it as a skeleton style clock and is charging a heck of a price.
I want to see someone try and wind it up with that big T-bar winder without smashing their knuckles into the base.
I also wonder if the spring rubs on the base when the clock is wound down.
I think I will pass on this one.
Ebay is great for a laugh sometimes.  I imagine this is what the seller will be thinking in about ten days time, "Hmmm... 'Skeleton' didn't work. I guess I'll try relisting it as 'Steam Punk'"
I wonder how long before the spring rubs the shaft just above it, maybe 2 days, also the Smiths dial has the winding holes bogged up, if you were going to add a different dial surly you would get one with just a centre hole in it. He also has a ventriloquists dummy for sale, I am thinking it is a selfie.
Edited by JimmyD
add photo
If he adds 'barn find' to the description, that makes it worth more, he's missing out.
