Daveo
Daveo
I have a vintage omega seamaster quartz and have fitted a new battery, but now the watch is running at approximately 30 times faster than it should. The watch has a small button next to the crown wheel,  on the back it has a number 1337. Any help would be appreciated. Thanks daveo.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
