Lubricants to use with Rolex 3135
Would the below list of lubricants be suitable for the Rolex cal.3135 (clone) movement?
For the grease (cannon pinion, keyless) would you prefer to use 9501 or 9504 the moebius chart recommends either.
This is from my post a few years ago (2015). If I remember correctly I used all of my suggested lubricants and the watch worked great. However after approx. six months the auto part stopped working efficiently. I re cleaned treated the wheels with epilame (fixodrop) and lubed with HP 500. Since then it has not been off my wrist part from bath time.
The epilame is really key, you have to do it. It's a weird quirk of an otherwise bulletproof movement. I think you could use pretty much any synthetic lube and it'd survive as long as you epilame the reversers.
Thanks nick I will look into it. It’s not something I’ve done before
On 3/15/2019 at 12:44 AM, matabog said:
Lubetta V105 on the reversers instead of Epilame?
Reversers are interesting for lubrication. Some of them you can use the Lubetta V105 Which is basically an oil like 9010 dissolved in a solvent. But Rolex in their tech sheet shows that lubrication only wants to be in a very specific location and nowhere else. So that's why the recommending the surface treatment to keep the oil from spreading.
On 3/17/2019 at 3:04 PM, matabog said:
I might have been wrong. I had the ETA reversers in my had. I think the rolex ones can be 'dismantled'. So after Epilame, where would you oil those reversers? And with what?
Lubetta V105 was developed I believe by ETA. The Rolex reverse wheels are of a different design. Lubetta I think is  lubricant. Most odd the Rolex reverse wheels have not lubrication.
  • 9 months later...
@JohnR725 So are the reverser wheels oiled on there edges or not ? The diagram shows 'do not oil', in which case what's the point of the epilame?
I notice that Mark applies a drop of something to the edge of the wheel ( 7min  50s) :
https://www.youtube.com/watch?v=J8WNrtahT4Q
My understanding is that the clicks or whatever they're called in the reversers have to be absolutely free to move and lubrication would Interfere with that. So epilame treatment is applied to keep lubrication away.  Notice they're using HP 1000 on the center part and there would be a likelihood without surface treatment of that spreading out.
Then you're absolutely correct in the video Mark applies a drop of lubrication on the reverser wheels which by theory would spread to the little clicks and interfere with how they work. But this is lubrication in horology everyone has a different idea if it works for Mark and long term it works for Mark then?
The reverser wheels MUST be treated with " Epilame" if not after a while the auto stops functioning correctly. I speak from experience. PS I used HP500 for the reverser parts with no issues the watch has not been off my wrist (apart from bath time) for 4 years now.
@clockboy do you know how long Epilame lasts? And what will dissolve it. Naptha, isopropanol?
I'm about to service a friends 2230 movement which has never been serviced :thumbsd:
And I'm not planning on buying any Epilame just for that!
(I wonder if there are any cheaper alternatives to Epilame. Mobile phone screens use an oleophobic coating which can be renewed with a wipe on liquid)
Edited by mikepilk
11 hours ago, nickelsilver said:
12 hours ago, mikepilk said:
I wondered if i clean in naptha then isopropanol it will remove the epilame
It might. It's really critical that they are epilamed, so try to get some. You can't really over epilame, but on these Rolexes you can definitely under epilame.
You have convinced me. I managed to buy just 5ml
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
