Lubricants to use with Rolex 3135
Would the below list of lubricants be suitable for the Rolex cal.3135 (clone) movement?
For the grease (cannon pinion, keyless) would you prefer to use 9501 or 9504 the moebius chart recommends either.
This is from my post a few years ago (2015). If I remember correctly I used all of my suggested lubricants and the watch worked great. However after approx. six months the auto part stopped working efficiently. I re cleaned treated the wheels with epilame (fixodrop) and lubed with HP 500. Since then it has not been off my wrist part from bath time.
The epilame is really key, you have to do it. It's a weird quirk of an otherwise bulletproof movement. I think you could use pretty much any synthetic lube and it'd survive as long as you epilame the reversers.
Thanks nick I will look into it. It’s not something I’ve done before
On 3/15/2019 at 12:44 AM, matabog said:
Lubetta V105 on the reversers instead of Epilame?
Reversers are interesting for lubrication. Some of them you can use the Lubetta V105 Which is basically an oil like 9010 dissolved in a solvent. But Rolex in their tech sheet shows that lubrication only wants to be in a very specific location and nowhere else. So that's why the recommending the surface treatment to keep the oil from spreading.
On 3/17/2019 at 3:04 PM, matabog said:
I might have been wrong. I had the ETA reversers in my had. I think the rolex ones can be 'dismantled'. So after Epilame, where would you oil those reversers? And with what?
Lubetta V105 was developed I believe by ETA. The Rolex reverse wheels are of a different design. Lubetta I think is  lubricant. Most odd the Rolex reverse wheels have not lubrication.
  • 9 months later...
@JohnR725 So are the reverser wheels oiled on there edges or not ? The diagram shows 'do not oil', in which case what's the point of the epilame?
I notice that Mark applies a drop of something to the edge of the wheel ( 7min  50s) :
https://www.youtube.com/watch?v=J8WNrtahT4Q
My understanding is that the clicks or whatever they're called in the reversers have to be absolutely free to move and lubrication would Interfere with that. So epilame treatment is applied to keep lubrication away.  Notice they're using HP 1000 on the center part and there would be a likelihood without surface treatment of that spreading out.
Then you're absolutely correct in the video Mark applies a drop of lubrication on the reverser wheels which by theory would spread to the little clicks and interfere with how they work. But this is lubrication in horology everyone has a different idea if it works for Mark and long term it works for Mark then?
The reverser wheels MUST be treated with " Epilame" if not after a while the auto stops functioning correctly. I speak from experience. PS I used HP500 for the reverser parts with no issues the watch has not been off my wrist (apart from bath time) for 4 years now.
@clockboy do you know how long Epilame lasts? And what will dissolve it. Naptha, isopropanol?
I'm about to service a friends 2230 movement which has never been serviced :thumbsd:
And I'm not planning on buying any Epilame just for that!
(I wonder if there are any cheaper alternatives to Epilame. Mobile phone screens use an oleophobic coating which can be renewed with a wipe on liquid)
Edited by mikepilk
11 hours ago, nickelsilver said:
12 hours ago, mikepilk said:
I wondered if i clean in naptha then isopropanol it will remove the epilame
It might. It's really critical that they are epilamed, so try to get some. You can't really over epilame, but on these Rolexes you can definitely under epilame.
You have convinced me. I managed to buy just 5ml
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
