Lubricants to use with Rolex 3135
Would the below list of lubricants be suitable for the Rolex cal.3135 (clone) movement?
For the grease (cannon pinion, keyless) would you prefer to use 9501 or 9504 the moebius chart recommends either.
This is from my post a few years ago (2015). If I remember correctly I used all of my suggested lubricants and the watch worked great. However after approx. six months the auto part stopped working efficiently. I re cleaned treated the wheels with epilame (fixodrop) and lubed with HP 500. Since then it has not been off my wrist part from bath time.
The epilame is really key, you have to do it. It's a weird quirk of an otherwise bulletproof movement. I think you could use pretty much any synthetic lube and it'd survive as long as you epilame the reversers.
Thanks nick I will look into it. It’s not something I’ve done before
On 3/15/2019 at 12:44 AM, matabog said:
Lubetta V105 on the reversers instead of Epilame?
Reversers are interesting for lubrication. Some of them you can use the Lubetta V105 Which is basically an oil like 9010 dissolved in a solvent. But Rolex in their tech sheet shows that lubrication only wants to be in a very specific location and nowhere else. So that's why the recommending the surface treatment to keep the oil from spreading.
On 3/17/2019 at 3:04 PM, matabog said:
I might have been wrong. I had the ETA reversers in my had. I think the rolex ones can be 'dismantled'. So after Epilame, where would you oil those reversers? And with what?
Lubetta V105 was developed I believe by ETA. The Rolex reverse wheels are of a different design. Lubetta I think is  lubricant. Most odd the Rolex reverse wheels have not lubrication.
  • 9 months later...
@JohnR725 So are the reverser wheels oiled on there edges or not ? The diagram shows 'do not oil', in which case what's the point of the epilame?
I notice that Mark applies a drop of something to the edge of the wheel ( 7min  50s) :
https://www.youtube.com/watch?v=J8WNrtahT4Q
My understanding is that the clicks or whatever they're called in the reversers have to be absolutely free to move and lubrication would Interfere with that. So epilame treatment is applied to keep lubrication away.  Notice they're using HP 1000 on the center part and there would be a likelihood without surface treatment of that spreading out.
Then you're absolutely correct in the video Mark applies a drop of lubrication on the reverser wheels which by theory would spread to the little clicks and interfere with how they work. But this is lubrication in horology everyone has a different idea if it works for Mark and long term it works for Mark then?
The reverser wheels MUST be treated with " Epilame" if not after a while the auto stops functioning correctly. I speak from experience. PS I used HP500 for the reverser parts with no issues the watch has not been off my wrist (apart from bath time) for 4 years now.
@clockboy do you know how long Epilame lasts? And what will dissolve it. Naptha, isopropanol?
I'm about to service a friends 2230 movement which has never been serviced :thumbsd:
And I'm not planning on buying any Epilame just for that!
(I wonder if there are any cheaper alternatives to Epilame. Mobile phone screens use an oleophobic coating which can be renewed with a wipe on liquid)
Edited by mikepilk
11 hours ago, nickelsilver said:
12 hours ago, mikepilk said:
I wondered if i clean in naptha then isopropanol it will remove the epilame
It might. It's really critical that they are epilamed, so try to get some. You can't really over epilame, but on these Rolexes you can definitely under epilame.
You have convinced me. I managed to buy just 5ml
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
