JW Benson "The Ludgate Watch"
I have a Benson Ludgate key set pocket watch, the silver case is hallmarked for London 1890, serial No. 70937.
I understand that Benson at the time had 3 main watches, The Field. The Ludgate, and The Bank.  Some say the Bank was the best, other say the Field, any ideas which was considered to be the top line?
About this time(1890) the Ludgate went keyless.
My watch has two known problems, the balance jewel is missing,( the bit that operates the "English lever" under the balance wheel) and the main spring winder is solid, not just fully wound with a little give, but rock solid!  The watch does not tick when shaken.
How do I remove this mechanism from the case?
There appears to be two releasing screws, but turning them has no effect.
If it's a simple job to remove the jewel from the cogs, and refit in the right place, I might have a go, other than that it will have to be looked at by a more knowledgable person than I.
Bod
Front bezel popped off, using a little pressure on the movement from the back.
Movement came out freely, all very clean, no dust or fluff. Could not see anything that looked wrong, the winding mechanism appears to be mainly between the main frame and dial.  Way beyond my skill set/pay scale!
Is this watch worth being set away?  Or is it only worth the scrap value of the silver case?
Bod
Checking sold prices on eBay any where between about £40 & £250 depending upon condition for one that actually ticks. Scrap silver is about 28p per gram for sterling. I guess it depends on how much you paid for it and what you want to do with it.
In good condition and fully repaired and serviced you may be able to expect the higher end of the sold price range but with the potential cost of the work you may not make much profit.
The watch was found whilst clearing my late fathers house, I'd never seen it before, and have no idea how he got it, or when.  The 1890 date doesn't tie in with any family history, a mystery.
I have now had the works out of the case, absolutely clean inside, no dust or fluff, the winding mechanism appears to be between the dial and main frame, way beyond my skill at present.
Are there any good books for the repair of this type of watch?
Bod
  • 1 year later...
Well to resurrect an old topic, due to being unable to go out,  I've had another look at this watch, discovering a few things.
1. My eyesight is not up to working on anything smaller!
2. The seized winding mechanism, was a small piece of straw under the intermediate gear.  How it got there goodness knows, the only holes big enough are on the other side of the watch.  No other debris or dust present.
3. The balance staff is missing.  The peg below the balance wheel, that moves the escape pallet arm.
Would the staff just be a short lenght of wire, or a shaped "jewel"?  The hole for this is round, no shaping.
Bod
Bod
For clarity @Bod, Think of the balance like a bicycle wheel. the balance staff is actually more like the "axle" that is the heart of the balance. In your case, it sounds like the roller jewel is missing. That is the bit that engages the pallet fork and cycles it back and forth with each swing (rotation) of the balance. In the image below the roller jewel is also called the impulse jewel, both terms are correct.
EDIT: I just looked at Ludgate movement online and I see the pallet is the older side lever pallet. So it looks quite different, however, the roller and fork arrangement are nearly identical and operate exactly the same.
Edited by FLwatchguy73
3 minutes ago, Bod said:
Thank you, it's the Impulse jewel thats missing.
I know I won't find a spare part, for this watch, but can they be replaced, with an alternative?
Bod
You can purchase an excellent running movement complete with pristine dial and hands here for $55 US if that helps any. It's a bit of an investment, but it may be worth it to you to have a fully functioning watch.
https://www.ebay.com/itm/J-W-Benson-at-London-Pocket-Watch-Movement-diameter-40-4-mm-HC-Ludgate/173921710984?hash=item287e8ab388:g:B6AAAOSwkIZc9Iks
Disclaimer: Above auction is not mine, just trying to be helpful and sharing information.
  • 2 years later...
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
