New Collector at Large
cellmend
Hi Guys,
My name is Justin and I am currently obsessed with watch design & movements. My hobby list is extensive, from brewing beer right through to Astronomy and everything in between lol. My wife has diagnosed me with a bipolar disorder in regard to the shed full of amazing projects and hobby related setups, which im absolutely fine with. The Watch Repair videos on youtube are just mesmerizing! I actually fall asleep to them of a night while in bed. They are very informative and great quality so I would also like to say thank you for your time sharing with us your wealth of movement knowledge in such a professional way. Keep up the good work!
