main spring got loose
luiazazrambo
Hi *,
Now I understand how can the mainspring damage the movement. First hand experience because I made a mistake at the end of the cleaning and oiling process. 3 o'clock in the morning. I felt the teethes bouncing of my chest. Needless to say I was and I am still very sad.
Best regards,
Lui
  • Sad 1
If empathy is helpful, a torsion clock I spoke about a few weeks ago suffered badly bent teeth when the mainspring let go, at some stage in the past (well before I laid hands on it, I'm pleased to say).
The pictures aren't brilliant but you can see the mashed up teeth between positions 6 & 7 o'clock on the wheel and at 8-ish o'clock on the barrel.
I straightened the barrel teeth out OK, managed to find a spare in place of the damaged wheel and (after sorting out former a repairer's 'adjustments' to the pallets and fitting the correct suspension spring) the clock's now fine.
It is easy to forget quite how much energy is in a spring.
Even a tiny watch spring is capable of launching projectiles across the room, and mangling delicate components in the process. While letting down the spring on one of the Timexes I was looking at, I lost my grip and the entire watch literally flew past my ear on to the floor.
Fortunately no damage was done, I was expecting a snapped seconds pinion or a damaged balance.  I did have to do a bit of crawling about to recover a couple of parts however.
The point is I guess, despite the fact that I was being particularly cautious I still managed to launch the thing in to orbit.
Clock springs are an order of magnitude more impressive when they get loose, so I would suggest always wearing eye protection when there is a chance of them escaping.
Yes empathy is helpful i felt really miserable at that point 3 o'clock in the morning. :) Well done with the repair!
On 3/13/2019 at 8:28 PM, JimmyD said:
Two rules I live with.
1) Allways let down the springs.
2) Never move the hands if any resistance is felt as it is a safe bet a tooth or teeth has been bent somewhere and you will only bend a few more.
This accident happened when I tried to test the clock at the end of the cleaning and re-assembly process. I try to always let the spring down before I start with a clock. (I only touched a few watches so far because I am a beginner.)
It was really painful because I was so proud that I fixed the broken mainspring (heated it up and created a hook and a lose end) then at the end of the process I ruined it. This is not a valuable clock but I just cannot stand this. :( :)
Edited by luiazazrambo
