Introductions
Sean
Good day, a while ago I felt the need for a hobby and I like collecting...things, so...why not pocket watches? I currently only have 6 or maybe it's 8? watches and am enjoying them. I believe the next start for me would be to gain the ability to service these things of marvel myself, and to a degree of professionalism. I have some movements coming my way that currently don't work, so I'll be disecting them to learn why, and perhaps even repair them, but the motive is to learn.
Is there a basic tool kit that a newbie ought to look to acquiring that you would recommend? Head mounted loupes? Lighting? Work stations? All suggestions welcomed and understand I am very new to this.
Thanks in advance,
Seán
Level one of Mark's watchrepairlessons goes through in nice detail what basic tools are required as well as giving you a nice grasp of what is involved in watchrepair. Judging from the fada, I don't suppose you are in Ireland Seán?
Sent from my Redmi 4X using Tapatalk
Thanks JBerry; I'm not in Ireland, or Irish for that matter, rather Canadian born and bred, of Scottish parents who came to Canada in the 1950's as teenagers themselves. The fada is a hold over from Britain where although Sean would invariably be pronounced "Shawn" by most, it can confused with "Shane" (Seán and Seàn respectively).
After making the introduction I noticed Mark's course curriculum. I may avail myself. ;-)
Thanks for the response, very much appreciated JBerry.
Seán
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
