Rolex Explorer II question.
My name is Dan. I am new to this forum. I am 60 and have been working on watches and clocks since I was 15. I just recently bought a pre-owned Rolex Explorer II Polar 42mm (Cal 3187 movement). I love the watch but have a question in terms of regulation. On the Timegrapher, the watch seems a bit more "out of beat" than I would expect from a Rolex. The milliseconds reading is 1.1ms on average. I was under the assumption that it should ideally be .3 or less. Is this true? And, if so, can anyone tell me how to adjust this number? Do I have to tweak the hairspring collet? or is there a dual regulator on the balance bridge? (I've yet to open the case) Thanks...
I think it would be helpful if you opened up your watch.  Googling there's a fair amount of information on the movement out there including the first link which has a nice picture of the balance bridge. Notice it has what resembles the standard Rolex stud holder for putting the watch in beat. Then you really don't want to mess with the Parachrom hairspring collet unless you have a special tool and you know exactly what you're doing.
https://rubberb.com/blog/technical-changes-of-the-rolex-explorer-ii-42mm/
http://static.rolex.com/flipboard/the-parachrom-hairspring.html
    • Unfortunately I'm not that lucky. I started on the train side and after I noticed the binding I pulled everything out except the driving wheel to rule everything else out. It still binds. I'm going to double check that the pinion is fully seated on the staff first, then if no joy I'll push the bridge jewel up a fraction of a mm. Fingers crossed!
    • Happy to have helped, great way to start the day with a win! 🥳
    • Thank you for the advise!! It worked. The setting screw was a lock/unlock to remove the rotor.
    • I have that French tech sheet too, it is a little different than the English one (eg, it doesn't have the auto works diagram). BTW, it looks like you are looking up the case number in the 1979 ABC supplement. The 1974 ABC catalog does have the 3093 case. As you determined it takes the 1222-5 crystal.  When I serviced my President 'A' (which also takes that crystal), I was able to fit a 29.8 crystal from my DPA crystal assortment. Those are, in my opinion, a great deal. The assortment comes with 10 sizes each from 27.8mm to 32.4mm in 0.2 increments. I pretty much use them for any non-armored crystal that takes a high dome crystal. I think they no longer make them but Cousins has still has some in stock but when I bought them they were around $40 for the set and now they are around $100. Still, at 40 cents a crystal it's still a good deal. For the large driving wheel, I remember I once assembled the keyless/motion works first and when I placed the large driving wheel it was interfering with the setting wheel on the dial side as the teeth were not fully meshing and it wouldn't fully seat. If that isn't the issue I got nothing and am looking forward to see how you solve it 🙂
    • Not sure, but just looking at it, it seems like the screw on the right may be a fake? The one on the left may not be a screw in the regular sense at all, rather a 2 position device, I think you need to point the slot towards either of the 2 dots and one will secure and one will open. Like I said this is just my best guess looking at the pictures.
