Loose barrel cover
Hi All
Recently acquired a Rolex 6303 with a Cal 645.
The barrel cover was loose from poor workmanship. I bought a similar Cal 600 cover which looks correct but still doesnt hold.
Is there a way to stake a barrel closed? I tried tapping the rim in a little but may have damaged a tooth. Please help!!!!!!!
If anyone has a source on Cal 645 parts I would be indebted. Willing to pay good money for a part to get this flipping watch back together (3 months on my bench so far).
Alex
If you own a lathe then you could spread some of the material (preferably in a vice rather than punching) and then turn it concentric if need be.
Has the barrel or barrel rebate been stretched or worn? It can happen when a spring suddenly breaks. On larger clocks this can even shatter the barrel wall (been there).
I don't have a lathe sadly.
The barrel cover appears flat as I ordered a replacement which was either NOS or very good condition. The original was flimsy and buggered.
It had been worked on by Indonesian watchmakers who are not to a very high standard. The watchmaker who sold the watch is based next to a rice filled.
He did bizarelly have a Jean Claude Dato Compax rolex in pieces on his bench!!!!!!!!!
Is a broken barrel tooth something that can be repaired? should I write off the barrel. Will it just slip past that tooth if I file it down?
Edited by AlexeiJ1
Check if the barrel wall is cracked.
Damaged tooth on barrel.. while the watch may work, there will be a shock to the train when the barrel reaches the broken tooth and releases. Not good for the train.
Your best bet would be to look for a new barrel with lid.
Good luck!
Anilv
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
