Aerowatch Neuchatel conversion...
Hi to you all....i am getting married in September and i have decide to buy a watch that will fit my suit :)...i have found a few over size watches and i just fell in love whit them. I am 1.96 m tall and small watches just dont fit my hand wrist.At this moment i have Invicta Corduba  model.3449 and trust me its like a wrist clock not wrist watch. I have using that watch evry day and now i just cant imagine my self whit small watch on my wrist.
 Those watches i mention above...i have realise that they are pocket watch conversions made in Ukraine. 1000 for and 1000 against....i am 1001 for :)...but also i have realise that they place price to much for old pocket watches whit some not original dials and Parnis watch cases. Sooooooooooooooooooo i have decide to make my own pocket watch conversion. I have found a nice Aero watch Neuchatel pocket watch whit beautifull dial, and it is moving whit UNITAS 6498 movment whic is in prestige condition. I know that UNITAS 6498 doesnt have shock resistance (its not INCABLOCK version) but i will not not wear that watch evry day. It will be more like memory for me...
After all i wrrite here is my problem....i have order Parnis watch case 45 mm square case and i somebody tell me that this case will not fit because its made for 0.8 mm dials and my dial is 0.4 mm.
Is that possible??? My dial diameter is 36,5 and its said on advertise that this case will fit any 6497 6498 st 36 movment and 35-37 mm dial. They didnt mention dial thicknes. And some other guy told me that most important thing is that i have to make shim 0.4 to insert beatween dial and movment so it will fit this case...is taht possible? will i have that problem or what?Pls help...
This is the case i order....https://www.ebay.com/itm/45mm-Square-Watch-Case-for-UNITAS-ETA-6497-6498-ST36-Movevement-Wristwatch/202507526147?hash=item2f2663a003:m:mHbKrPFx7xBQ3ECUAhCTscg
Hello
It sounds like a cool little project you got going on here.
I'm not very familiar with these Parnis cases but the theory is the same for the most.
The pocket watch movements are mostly put into place by opening the front lid and dropped into place, this means it doesn't matter which thickness you got on the dial since the distance to the winding stem center and the tube in the case will be adjusted by the backside of the dial.
But on wristwatches the movement is most likely placed from the bottom and against an edge inside the case, now the position of the center of the stem is decided by the fromt of the dial. If the dial is supposed to be 0.8 mm thick but instead is 0.4 mm the center of the stem will be 0.8 - 0.4 = 0.4 mm off towards the center of the tube in the case.
If this offset matters or not is depending of the clearance in the tube. One  always should strive for perfection so the easy fix is to put a shim under the dial.If you can't find a factory made shim you can always buy a sparkplugg gap measuring tool from the local gasstation for 1$ or two and use the 0.4 mm blade for your shims.
You are built on Slavic battle Chassis. No small watches for you.You could use something soft and easy to work and less likely to corrode ,brass or plastic.Stainless (inox as you call it) is hard to cut and has nasty sharp edges. Congratulations on your upcoming marriage.
Edited by yankeedog
content
Upssss i bought abother one :)....this one is whit inca block....its eta 6498-1 movement and not so good condition as my watch maker told me...it was used heavely...it was used like every day watch...its works fine but it happend that he stop two times...what could be problem..and here is one picture what am i usjng like evry day watch and pocket watch :))just to se the scale :))676bc5161dc3489b42c9a7241a6972cd.jpg639b3ca0e74d787388738d09f454ca4b.jpg0d02021fdd20f0756782e3a694d7205a.jpg4bb0cf557dde10eae89e97e168976ad3.jpg
Послато са GT-I9301I уз помоћ Тапатока
  • 4 weeks later...
Still i didnt place movement holders into case. Waiting them to arrive from Malasiya. But so far this is how it look like. I have trim the winding steam..hand made leather strap 28 mm on watch and 26 mm on buckle. Overall looknice :)b8998ab478e274a0db210a80399e52c8.jpg1e84d74e051f3028598331472e9866ee.jpgbef663356417d6db5e2d760ef0733981.jpg9abdac89dab345fb8424285f30694d07.jpg
Послато са SM-J600FN уз помоћ Тапатока
is it the picture, or is there a slight dial misalignment
Yes it is and it doesnt fit case that i bought...on advertise it said that will fit 40-41.5 mm dial. My dial is 40 mm and it drop down the case. I have bought this dial from e bay down on the picture but now i have dilema will this dial fit my movement.my movement is 6498-1 and this dial is 6498. Are they compactibile? Will it fit???75d133d30eb391e4cf191fcd183bd911.jpg05f6ac45949e87260f75c4976c2a497a.jpg
My best answer is probably. Your movement is a 6498-1. This means it has some revision over the standard 6498. I do not know what the revision is.  Probably it is nothing major such as changing the dial feet position.
It will fit :)))
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
