New member
TRyan
Hi All,
I'm currently trying to sell some watch making tools on behalf of a family member and I came across this website while researching a Bergeon platax tool (2677) that I have.
Seemingly they are quite rare and sought after!
Is it ok to post items for sale here straight away?
Thanks, Tim
Thank you for your introduction and welcome to this friendly forum.
Sorry TRyn. You better read this.
Items for sale
We have decided that this forum is not to be used for the promotion of items for sale by members, and to concentrate on building this forums reputation as a community website dedicated to the discussion of watch repair and horology related matters. Therefore, promotion of items for sale by members is not permitted on this website.
Thanks for the reply!
No problem, that's why I asked here first. I plan on keeping some of the tools and attempting to repair a few of the pocket watches myself so I'll stick around!
I have some of the items listed on various groups on Facebook too if anyone wants to contact me about the tools.
Tim
I'll try and advertise it on eBay too. Although I've noticed that some items I have listed don't easily appear on other people searches for some reason, even with the exact title searched.
I'm looking to sell it to pay for some legal fee's, the joys of dealing with a deceased persons house who didn't leave a will :)
Thanks for the advice!
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
