Elgin Sportsman caseback
Yes, it would be a snap off back. Dig under the bottom of it where it meets the case. It may very well be a little corroded and stuck to the case. Carefully try slinging a single edge razor blade under it and lever it upward. It may break the blade, but I always have a box of them on hand for when the gap is too small for a screwdriver blade or knife blade. Steve
Sent from my iPad using Tapatalk Pro
Snap back...if you take a loupe and inspect the edge you may find place that is designed for prying such as a small lip or indentation.I believe that watch will have a jeambrun movement.It should run well for you.Be warned...the back will be just as stubborn to put back on.
Edited by yankeedog
Content
