A clock challenge !!!
clockboy
It is an Ansonia, and as OH said parts are easy to get just buy an old movement off eBay if you need any. The movement will have a number on the bottom right side of the faceplate something like, 9 or  9 1/2 so it is easy to get the right one for parts. It will clean up okay as well, here is one I did about a year ago.
a-IMG_9965-1.thumb.png.c001c56517118e507769dc549262d74d.pngd-IMG_0024-1.thumb.png.b4dc47fedb8651c8d1a104bc45d45c8f.png
15 hours ago, Squiffything said:
It's an Ansonia Clock co. "King" Shelf or mantle clock. Available in oak and walnut and possibly other exotic woods. Lovely engraved glass door.
The glass door is just a transfer, you can still buy them today.
Ok guys thanks as I thought. Three issues found so far. The case is falling apart I suspect the glues have dried. One of the mainsprings end is broken which might be repairable and the third the suspension spring is snapped off. I am sure I will find other faults such as worn bushing etc.
What fun!!
I always gave an estimate for repairs no matter how small or large. Write up the work carried out and any parts made or replaced handed back.
If you have the time this would be a good project to photo in stages to the work carried out. A before and after explaining so others can see the re-build from pieces to the completed task.
On 3/7/2019 at 12:03 PM, clockboy said:
I have had this one arrive yesterday "no hurry was the message"  bit of a challenge to say the least. I think it is american  but a complete wreck. It is close friends so I will give it a go but IMG_3192.thumb.jpg.f5dffcf671b07c4ac7fc5bcb6bc19b3b.jpgIMG_3190.thumb.jpg.2ec4e7e2b27a0fee72055e515dea8d9d.jpgIMG_3191.thumb.jpg.ab2f62b76c037ae8fa4010ebf5370998.jpgWish me luck
You always seem to get the challenging ones CB..It will be a lovely clock when finished..
I am not sure how familiar you are with this type of movement so just a pointer when assembling the movement.
The lever that goes into the cam (oval ) and the count wheel (circle) need to be set up like you see them as you put the movement together as there is no adjustment later. The set lever is on the other side of the 1st cog (square)  after the fly, I position the pin about opposite to the lever stop which is normally enough set for the count wheel/cam lever to start when the set lever drops.
Point 2, you need to have the hands shaft lifting lever in the dropped position as the minute hand has no adjustment, if not it could start the train/gong at anytime between the 3/4 and hour.
You may know all this already, however for others that are reading this and do not, the best way to save issues later is to take photos before dismantling and also maybe draw where the levers are on a pad as when you try to take it apart many of the cogs will lift out no matter how carefully you try to get the plate off.
Thanks Jimmy this is the first one of the movements for me so very helpful pointers. As a matter of habit I do take pics of any striking movement, paying attention to where the pins and levers are positioned. As you say it can save a lot of time.
Hi Clockboy      There is plenty of info on these clocks I have a couple and a spare movement. Checkout articals by David LaBounty he has some good drawings on the lever arrangements worth a look. as clocks they come up pretty well,  interesting project you will enjoy it.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
