Timex Camper Restoration
JerseyMo
Night two - cleaning parts.
Ultra sonic cleaning in some ammonia for 6 minutes than let sit for few more.  Dry all and inspect.  They all look good.
Since the main spring was broken, I took one from a donor.  To test it I held it in place and with a pair of pliers I turned the arbor to see if it would hold and it did.
Night two -  reassembly continued drop in the train and add the back plate.
with just a few gentle taps the back plates falls into place.  Next is to flip it over and insert the pillar screws and the rest of the parts..
and give it a wind.
Edited by JerseyMo
This all looks very familiar.
I was surprised to find that getting all of the pinions to pop back in place was considerably easier than I expected. I did resort to a couple of small blobs of rodico to hold some things in place while I fiddled about, but all in all it was not much more tricky than putting an alarm clock back together.
I must admit that I had the autowinder on one of mine off and back on several times before I was happy with its performance, and it took a moment or two to figure out what the little copper washer was all about,  but other than that, they are actually pretty co-operative when it comes to servicing.
No flying clicksprings or exploding barrels.
Who says you cant service a Timex? :D
it has really been bugging me to get this movement back to running.  so tonight I compared the original barrel that was in there to the one that the main spring will slip.  to no surprise, I could see the dimple that hold the tail of spring in place was well wound.  Where as on the original, the dimple showed little to no wear.
So now I have to figure out how to wind in a replacement spring since I don't have winding tools.  Well maybe now I have the reason to finally buy some. Oh well.....
I am not all that familiar with Timex gizzards...there is a balance and a pallet..will it spin with them removed?  Try spinning it submerged in mineral spirits..could be a bit of dirt hanging it up somewhere.
Edited by yankeedog
Content
all of the parts were cleaned twice and it does run a bit than stop.  my thought is wear to the train.  I'll have to inspect each part closer.
I would just swap in another movement but, these Campers have a unique movement.
For now this one will take a  back seat as I prep others for EBay sales.
2 hours ago, AndyHull said:
how does it look on the time grapher?
I have found this era of off shore manufactured Timex to have the lowest serviceability.  This can only be contributed to the lowering of the materials used.  If you compare for example the recovery of a mid 1960's model 24 to an early 1980's model 106.  The early #24 return back to service more consistency.   So when I begin to work on any Timex from the late 1970's and newer I do so knowing the success rate will be less.  Now the odd thing is when it comes to these Campers the success rate goes up.  Which is the reason I look for them.
That aside, I have a hunch what the issue is and will give it a try next.
Runs and stops? friction where it is not supposed to be ,or something eccentric.Only thing I can think to do at this point is to take it back apart and reassemble in stages .If you put it back together,one cog at a time downstream from the mainspring you should be able to find the rub.
On ‎3‎/‎6‎/‎2019 at 3:21 PM, JerseyMo said:
only those who did not try or want to try.
   there were lots of Timex of that style in the U S military - 1968 - some made with 17 jewels and radioactive dials. see my photo gallery.   vin
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
