Timex Camper Restoration
JerseyMo
Night two - cleaning parts.
Ultra sonic cleaning in some ammonia for 6 minutes than let sit for few more.  Dry all and inspect.  They all look good.
Since the main spring was broken, I took one from a donor.  To test it I held it in place and with a pair of pliers I turned the arbor to see if it would hold and it did.
Night two -  reassembly continued drop in the train and add the back plate.
with just a few gentle taps the back plates falls into place.  Next is to flip it over and insert the pillar screws and the rest of the parts..
and give it a wind.
Edited by JerseyMo
This all looks very familiar.
I was surprised to find that getting all of the pinions to pop back in place was considerably easier than I expected. I did resort to a couple of small blobs of rodico to hold some things in place while I fiddled about, but all in all it was not much more tricky than putting an alarm clock back together.
I must admit that I had the autowinder on one of mine off and back on several times before I was happy with its performance, and it took a moment or two to figure out what the little copper washer was all about,  but other than that, they are actually pretty co-operative when it comes to servicing.
No flying clicksprings or exploding barrels.
Who says you cant service a Timex? :D
it has really been bugging me to get this movement back to running.  so tonight I compared the original barrel that was in there to the one that the main spring will slip.  to no surprise, I could see the dimple that hold the tail of spring in place was well wound.  Where as on the original, the dimple showed little to no wear.
So now I have to figure out how to wind in a replacement spring since I don't have winding tools.  Well maybe now I have the reason to finally buy some. Oh well.....
I am not all that familiar with Timex gizzards...there is a balance and a pallet..will it spin with them removed?  Try spinning it submerged in mineral spirits..could be a bit of dirt hanging it up somewhere.
Edited by yankeedog
Content
all of the parts were cleaned twice and it does run a bit than stop.  my thought is wear to the train.  I'll have to inspect each part closer.
I would just swap in another movement but, these Campers have a unique movement.
For now this one will take a  back seat as I prep others for EBay sales.
2 hours ago, AndyHull said:
how does it look on the time grapher?
I have found this era of off shore manufactured Timex to have the lowest serviceability.  This can only be contributed to the lowering of the materials used.  If you compare for example the recovery of a mid 1960's model 24 to an early 1980's model 106.  The early #24 return back to service more consistency.   So when I begin to work on any Timex from the late 1970's and newer I do so knowing the success rate will be less.  Now the odd thing is when it comes to these Campers the success rate goes up.  Which is the reason I look for them.
That aside, I have a hunch what the issue is and will give it a try next.
Runs and stops? friction where it is not supposed to be ,or something eccentric.Only thing I can think to do at this point is to take it back apart and reassemble in stages .If you put it back together,one cog at a time downstream from the mainspring you should be able to find the rub.
On ‎3‎/‎6‎/‎2019 at 3:21 PM, JerseyMo said:
only those who did not try or want to try.
   there were lots of Timex of that style in the U S military - 1968 - some made with 17 jewels and radioactive dials. see my photo gallery.   vin
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
