Timex Camper Restoration
JerseyMo
Night two - cleaning parts.
Ultra sonic cleaning in some ammonia for 6 minutes than let sit for few more.  Dry all and inspect.  They all look good.
Since the main spring was broken, I took one from a donor.  To test it I held it in place and with a pair of pliers I turned the arbor to see if it would hold and it did.
Night two -  reassembly continued drop in the train and add the back plate.
with just a few gentle taps the back plates falls into place.  Next is to flip it over and insert the pillar screws and the rest of the parts..
and give it a wind.
Edited by JerseyMo
This all looks very familiar.
I was surprised to find that getting all of the pinions to pop back in place was considerably easier than I expected. I did resort to a couple of small blobs of rodico to hold some things in place while I fiddled about, but all in all it was not much more tricky than putting an alarm clock back together.
I must admit that I had the autowinder on one of mine off and back on several times before I was happy with its performance, and it took a moment or two to figure out what the little copper washer was all about,  but other than that, they are actually pretty co-operative when it comes to servicing.
No flying clicksprings or exploding barrels.
Who says you cant service a Timex? :D
it has really been bugging me to get this movement back to running.  so tonight I compared the original barrel that was in there to the one that the main spring will slip.  to no surprise, I could see the dimple that hold the tail of spring in place was well wound.  Where as on the original, the dimple showed little to no wear.
So now I have to figure out how to wind in a replacement spring since I don't have winding tools.  Well maybe now I have the reason to finally buy some. Oh well.....
I am not all that familiar with Timex gizzards...there is a balance and a pallet..will it spin with them removed?  Try spinning it submerged in mineral spirits..could be a bit of dirt hanging it up somewhere.
Edited by yankeedog
Content
all of the parts were cleaned twice and it does run a bit than stop.  my thought is wear to the train.  I'll have to inspect each part closer.
I would just swap in another movement but, these Campers have a unique movement.
For now this one will take a  back seat as I prep others for EBay sales.
2 hours ago, AndyHull said:
how does it look on the time grapher?
I have found this era of off shore manufactured Timex to have the lowest serviceability.  This can only be contributed to the lowering of the materials used.  If you compare for example the recovery of a mid 1960's model 24 to an early 1980's model 106.  The early #24 return back to service more consistency.   So when I begin to work on any Timex from the late 1970's and newer I do so knowing the success rate will be less.  Now the odd thing is when it comes to these Campers the success rate goes up.  Which is the reason I look for them.
That aside, I have a hunch what the issue is and will give it a try next.
Runs and stops? friction where it is not supposed to be ,or something eccentric.Only thing I can think to do at this point is to take it back apart and reassemble in stages .If you put it back together,one cog at a time downstream from the mainspring you should be able to find the rub.
On ‎3‎/‎6‎/‎2019 at 3:21 PM, JerseyMo said:
only those who did not try or want to try.
   there were lots of Timex of that style in the U S military - 1968 - some made with 17 jewels and radioactive dials. see my photo gallery.   vin
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
