3D Printed Cases
This may be old news but for me its new. As some of you may know I have been working on a few projects lately. One included a from scratch build. Ive benn tinkering with 3D Printed Cases and heres what ive got so far. The gold filament has produced a better than expected product. Sizing is a bit tough for fitment as the printer doesnt always print to scale but once dialed in repeatability is acheivable. I have a 170 and a 7750 planned for these case. I will post in those build threads but wanted to get this result out as Im pretty excited about the product. c0d6c6d9004c89e8d8d08afb791e015d.jpg0a5ba2bfe938d8c45a4c47f239a6995d.jpg
Sent from my SM-G950U using Tapatalk
Here's a trick you might like to try if you have the necessary capability. I have no idea how good the results are likely to be, but it is on my to do list.
Polish the case to a smooth finish (1000 grit or so). Next coat the plastic with graphite to make it mildly conductive, then copper plate it.
This would then allow nickel plating on top of the copper.
Strictly speaking this is probably better described perhaps as electrotyping or as electroforming rather than electroplating, as the substrate is plastic rather than metal, but lets not split hairs.
This is one of the methods used to produce bright shiny "metal" plastic parts, and is probably much easier to attempt at home than vacuum sputtering or sintering.
Simply fine polishing the metal filament model may produce a pleasing result, without going as far as to electroplate.
Caswell makes a spray. But even better there are conductive filiaments. Its def crossed my mind. What I really want to do before that is get my hands on an SLA printer. They have an much higher resolution and there are plastics that they use that can be electroplated from the start.
I'm not familiar with that brands products but I have used one conductive spray and the result depends lots of the preparation work.
Grinding with a fine sandpaper and spaying a couple of times with a grind with 2000 grit sandpaper after every layer gave a smooth surface. It's little like spraying a car.
I use the silverspray to make a gold plating.
Ive ordered some of the conductive filament. I have so many projects going on right now. Lol.
The filament should do the trick too. It was a while ago i tried out these products not just on watchprojects but also on mobile phone cases, for the kids.
The only disappointment was the thickness of the plating which seemed to wear of quite fast.So it seems the product I used isn't very partyproof ;) .
You could also use it as a mould to do resin cast / cold cast from. What resolution are you printing it at ? I'm not sure my 3D printer would be accurate enough
Not a bad idea. I have my eye on an SLA model. This one has a layer resolution of about 250 microns.
That is the one I currently have has a 250 micron resolution. The SLA is a resin base and the resolution is far better.
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.  Thanks, Nev. Amplitude v. weak - balance wheel turns over arc of only ~20deg. Don't know how to calculate movement rate or safely vibrate balance spring! Meantime I have reduced the 'dishing' & clock no longer runs for more than a few minutes except face down which supports my theory that it was 'dished' as a hack to avoid doing a proper repair.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
