Platax
Colditz
I recently bid for a second hand Platax tool. It looked quite worn so thought I'd get it a reasonable price. Oh no it went for 650 Euros, well out of my price range and I think for that price it would have to be new. Evidently I will never get my hands on a Platax Tool and the price will only increase as they become rarer.
Bergeon no longer supply this tool what is a reasonable alternative  to enable the replacing of balance staffs? and is  there a video of the alternative?
Help please. Thanks
If you have a staking set you could go for a Kendrick and Davis staff remover or a Unruh Max remover but I think both are more suited to pocket watch staff removal. There are videos on u-tube of the kendrick and Davis removers. And the topic has been covered on this forum before just do a search for it.
Both are far cheaper than a Platax, but keep your eyes peeled on ebay sometimes they pop up as buy it nows a reasonable prices.
And try German ebay used watch tool prices are far more reasonable than U.K ebay and often don't show up in English ebay searches.
There are alternative methods of staff replacement but there is no tool available like the Platax which is why it's such a shame they chose to discontinue with it,.
You can remove a staff on a lathe if you have one, you have to turn away the rivet with a graver to remove the staff, or you can use the kendrick and Davies or Unruh Max together with a staking set to remove staffs, I've never removed small staff's with the Unruh Max because I have a Platax, but I have used it with pocket watch staffs and it is far quicker than using the Platax, its a simple plunger type device that is spring loaded a sharp push downward clamps the wheel to the staking plate and pushes the staff out.
Edited by wls1971
  • Similar Content
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
