Stem Removal
My gf has an old watch with an hattori VC11 quartz movement, being such a cheap movement to replace i figure dont  fix it but just replace.  However i cant for the life of me remove them stem. Can anyone please help me with how to remove the stem from this movement? Thanks in advance.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
