Watches
Is this a good way to clean a Quartz movement?
Cleaning the a watch movement
Watches accumulate over time dust and small metal debris inside the movement. All watches have a friction fit to allow you to change the time while the movement is running. If there is oil on that friction fit then the movement will not be able to drive the watch hands any more properly. The friction fit will slip and the time will be off. A quartz watch that is off by several minutes per week has usually mechanical problems, not eclectic problems.
Quartz movements are more simple in their mechanical design. They have very few cog wheels and it's easy to get to them. This open design does often allow you to wash the movement in lighter fluid without taking it apart.
Lighter fluid to clean watch movments.
To clean a quartz watch you just take the movement out of the case, dip it in a small bowl with lighter fluid and move it a bit left and right to allow for the flow of lighter fluid through the movement. This will wash old oil, debris and dust out of the movement and you will find small particles at the bottom of the bowl.
I have installed a new battery just a few month ago and now the watch needs again a new one
If you are sure that the battery is was of good quality then this is probably a sign of oil in the movement getting old and sticky. The friction in the movement has increased.
An easy way to fix this is to first apply a bit of very thin Moebius quartz oil. After that you wait a few days (watch running) until the oil got into all the pivot holes where it dissolved the old and sticky oil. Finally you wash the excess oil away with lighter fluid. Just wash the entire movement in lighter fluid. Traces of oil will remain in the movement and that is enough. You don't need to take the movement apart for this procedure.
I would say no.
Dipping the movement complete is a bad idea.
Quartz watches have many plastic parts in them that may react badly to lighter fluid, also it will not clean the pivots correctly.
I personally think that pretty much everthying above is bad advise.
Quartz watches still need to be dismantled to clean and oil correctly.
Maybe if its a $2 watch and its not worth the time to service it correctly and you just hope to get a few more months out of it the above might be worth trying, but other than that I advise against using teh above cleaning instructions.
Tmuir, I heard the fluid may actually hurt the circuitry, in some cases the movement will run  but drains the battery within a few months. What is your thought on that.
The very few quartz movements I have overhauled, it is been complete tear down, brushed parts in friendly fluids and oiled as if mechanical. The result have offcourse been to my satisfaction. But wouldn,t that defeat the idea of quartz accuracy and no repair pain? Or is no repair my overexpectation.
Joe
Joe
I suspect a tongue-in-cheek thought when you posted about the no repair expectations for a quartz watch. Many quartz movements were designed to be serviced. One of my quartz watches sports a 13 jewel movement. Unfortunately, economics gets in the way. A complete, new, 13 jewel Ronda 5030.d movement, Swiss made, can be had for less than $50 USD. A Swiss Parts version, 6 jewel, can be purchased for less than half that amount. I don't personally know any professional watchmakers who will disassemble, clean, oil and reassemble a movement for $50, much less $25.
You're going to see more serviceable quartz movements if the Seiko produced meca-quartz type catches the public's attention. It is a hybrid chronograph at this time. The 'engine' that provides the motive power is quartz but the mechanics that power the chrono functions are all mechanical. You gain the satisfying feel and operation of a mechanical chronograph while powering it with a stable, long lasting quartz power source. Win/win.
Don't get me wrong. I'm not predicting the demise of the mechanical watch movement at all. Merely another way to produce similar results.
Edited by TexasDon
I agree it could damage the circuitry, it could also shift oil and dirt onto the tracks causing shorts, also if there is any metal dust within the movement cleaning it together could shift it towards the rotor where it will stick causing other issues.
Quartz watches still eventually need servicing, its just a lot of modern quartz movements are made not to be serviced.
My daily wear watch is a Seiko 7546-8360 quartz watch from 1978. It was bought non functioning but it just needed a strip down clean and oil and obviously a new battery. I'm pretty confident that's the first service the watch had and it probably wont get another one for 10 or 20 years.
As TexasDon states if you want the movement to continue to work it still needs to be correctly serviced, but the cost to service compared to replace means it usually doesn't happen unless its a high end movement.
Edited by Tmuir
7 hours ago, Tmuir said:
I would say no.
    a good cleaner is alcohol!  find it at rhe chemists shop.  vin
I am inclined to think alchohol would pose the least or no risk, especially if a quick dip,  evaporates real quick.
TexasDon, no tongue in cheek, seriously, I got a watch that started draining battery following such a dip, I was being told the fluid damaged the circuit, some say a short circuit somewhere, fifteen years on I still don,t know the real cause. So I asked.
I still got the watch, kappa brand, swiss EB, metal gears and big jewels looks pretty too. Can I interest you in a trade off, goat for horse .:lol:
Regards
I'm not sure if lighter fluid will affect the circuit board, but I suspect not, however it may dissolve some plastics, and soften others, so I would be a little cautious when using it on quartz movements.
Isopropyl alcohol (aka isopropanol)  might be safer, but then again, it might not be as effective at dissolving the build up of oily grime.
Back in the day, we used to use 1,1,1-trichloroehane to clean circuit boards, and as a degreaser, but that is an ozone destroying solvent banned in 1996, so unless you have some lying about, then you will need to use something which is most likely less effective.
I have used isopropanol extensively over the years to clean plastic parts, and remove soldering flux residue and other grime, and it is reasonable effective in most cases. I am not aware of it damaging plastics, but I guess the proof might be to sit a working quartz movement in some for a week, then remove it and see if it still works. I suspect it will be fine.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
