Metamec, the cheap throw away.
Squiffything
I had another look and will inform you of the things that stand out.
The hammer is in the wrong place (can be fixed) it would hit the wall.
The pendulum bob and the hook at the top of the pendulum are the only original bits of it and that is debatable.
Looking at the movement, the escapement pinion at the cog end looks bent.
The pinions if you look across the clock are not parallel, the escapement pinion to the fly/fan is way off parallel as is the pallets to the other two above, if this was just and angle thing the latter 2 would be the same offset angle, however they contradict themselves.
If you wanted a clock to keep and be proud to have on your wall then this is not it as you would need to get an original pendulum and fix all that is wrong with it, and the cost would end up more than the clock is worth.
These clocks come on eBay in Oz a lot so there must be many more in the UK and USA that are all original and cost maybe around 200 quid that still need fixing however you would have an all original clock.
The movement is original so it should give you an idea of what to look for.
Soak it up.....:phew:
Thanks Jimmy, it’s a lovely looking thing and at the price would have made a nice little project but as there is little left of the original not worth the investment.
As mentioned before I’m after picking up cheap movements to learn about. I have spoken to the guys at the BHI and they recommend that I try and get hands on experience along side doing the course. As there are few clock repair guys around it’s difficult so building up a collection of movements to work on is one way to go.
I’m working on the metemac again. The balance spring is out. It’s deffo cupped as Jimmy said so a complete dismantle and rebuild. It’s now a little more like it should be.
Damn I enjoy this. I can spend hours pulling these things apart and rebuilding and not even notice the time that has passed. I notice I’m getting quicker as the familiarity sinks in.
Error made earlier though, I didn’t quite get the main spring ring set properly when I let it go, it pinged a nut across the room like a bullet and shot the cat. He’s old and a little constipated but man did he crap himself. Loosened up a load :)
The cat looks guilty, I bet it is thinking " ignore me and my lunch for stupid clocks will you"
I remember watching a doco about apprentice clock/watchmakers in Switzerland years ago and a girl lost a screw off a watch on the floor, 5 of them looked for it for about 30 minutes and this floor was white and spotless, they did find it, so there is hope Squiffything.
When working on stuff that might fly away on the ISS, they use a glove box. Maybe I need to build myself one of those.
I'm not sure how I would get my magnification arrangements to work with it though.
Edited by AndyHull
I found it! Woohoo. It was embedded in the rear section of the dogs hind quarter. Talk about tearing him a new ring! It’s ok he’s settled down a bit now but it’s interesting watching him squirt out a double walnut whip ;)
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
