Metamec, the cheap throw away.
Squiffything
I had another look and will inform you of the things that stand out.
The hammer is in the wrong place (can be fixed) it would hit the wall.
The pendulum bob and the hook at the top of the pendulum are the only original bits of it and that is debatable.
Looking at the movement, the escapement pinion at the cog end looks bent.
The pinions if you look across the clock are not parallel, the escapement pinion to the fly/fan is way off parallel as is the pallets to the other two above, if this was just and angle thing the latter 2 would be the same offset angle, however they contradict themselves.
If you wanted a clock to keep and be proud to have on your wall then this is not it as you would need to get an original pendulum and fix all that is wrong with it, and the cost would end up more than the clock is worth.
These clocks come on eBay in Oz a lot so there must be many more in the UK and USA that are all original and cost maybe around 200 quid that still need fixing however you would have an all original clock.
The movement is original so it should give you an idea of what to look for.
Soak it up.....:phew:
Thanks Jimmy, it’s a lovely looking thing and at the price would have made a nice little project but as there is little left of the original not worth the investment.
As mentioned before I’m after picking up cheap movements to learn about. I have spoken to the guys at the BHI and they recommend that I try and get hands on experience along side doing the course. As there are few clock repair guys around it’s difficult so building up a collection of movements to work on is one way to go.
I’m working on the metemac again. The balance spring is out. It’s deffo cupped as Jimmy said so a complete dismantle and rebuild. It’s now a little more like it should be.
Damn I enjoy this. I can spend hours pulling these things apart and rebuilding and not even notice the time that has passed. I notice I’m getting quicker as the familiarity sinks in.
Error made earlier though, I didn’t quite get the main spring ring set properly when I let it go, it pinged a nut across the room like a bullet and shot the cat. He’s old and a little constipated but man did he crap himself. Loosened up a load :)
The cat looks guilty, I bet it is thinking " ignore me and my lunch for stupid clocks will you"
I remember watching a doco about apprentice clock/watchmakers in Switzerland years ago and a girl lost a screw off a watch on the floor, 5 of them looked for it for about 30 minutes and this floor was white and spotless, they did find it, so there is hope Squiffything.
When working on stuff that might fly away on the ISS, they use a glove box. Maybe I need to build myself one of those.
I'm not sure how I would get my magnification arrangements to work with it though.
Edited by AndyHull
I found it! Woohoo. It was embedded in the rear section of the dogs hind quarter. Talk about tearing him a new ring! It’s ok he’s settled down a bit now but it’s interesting watching him squirt out a double walnut whip ;)
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
